Vert Top Sticks
Old Sep 9, 2008 | 10:47 AM
WhtRkt's Avatar
WhtRkt
Lifetime Member
Default Vert Top Sticks
Having a problem raising my top. It seems to stick about half way when raising it. I have to manually raise or give it a nudge.
Anyone had this problem?
Old Sep 9, 2008 | 11:28 AM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
had a similar problem with our 05. It turned out to be the pressure release screw backed out, allowing enough pressure to get started, but not to finish lifting the top. The pump is under the waterfall hatch, pass side behind the carpet. The screw is on the side of the pump/reservoir.
Old Sep 9, 2008 | 11:52 AM
Ben Diss's Avatar
Ben Diss
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
Do you hear the motor whining when it stops? I'd take it to the dealer and get them to fix it. Under warranty still?
Old Sep 9, 2008 | 03:24 PM
WhtRkt's Avatar
WhtRkt
Lifetime Member
thanks...I will give that a try.
Old Sep 9, 2008 | 03:25 PM
WhtRkt's Avatar
WhtRkt
Lifetime Member
No whinng noise ( other than me). Not under warranty anymore. Thanks for our reply
Old Sep 9, 2008 | 05:50 PM
Ben Diss's Avatar
Ben Diss
Then it's probably a sensor. Look on the right for the sensors and see if one got knocked out of place.
Old Sep 10, 2008 | 12:59 PM
cclive's Avatar
cclive
So, to be clear, the pump makes noise pushing the top up and then it becomes completely quiet when the top sticks? And then it starts making noise again when you give it a nudge?
To Vert Top Sticks
