Oil usage problem, help
Old Sep 10, 2008 | 02:54 AM
DONALD HALL's Avatar
DONALD HALL
Default Oil usage problem, help
Hi All,
My car did not use any oil between oil changes, until, I had new ported heads installed. Now the car uses about 1 quart about every 2000 miles. The car is driven the same now as before, which is easy. All the plugs look ok and all the same. The only place, I can think of, where the oil may be comming from is the valve stem oil seals. What do Yall think???
Old Sep 10, 2008 | 07:17 AM
1.8t's Avatar
1.8t
Originally Posted by DONALD HALL
Hi All,
This is what I was thinking.
Old Sep 10, 2008 | 09:45 AM
Mike Francoeur's Avatar
Mike Francoeur
What brand heads are they. Some are known for it, Shoot me a PM, email, or give me a call if you'd like...
Old Sep 10, 2008 | 03:19 PM
VET4LES's Avatar
VET4LES
Valve stem seals are my guess also.
To Oil usage problem, help
