Question on quick shifts with short shifter??
Old Sep 13, 2008 | 06:43 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Default Question on quick shifts with short shifter??
I recently went with the MGW short shifter, and love the precision of it. It works GREAT for aggresive driving through the canyons. On the few times I've gone for a quick run through the gears/straight a way pulls, I've ground the gears a couple of times.
I believe I need to reprogram my brain and shifting. I now need to clutch just a hair sooner before putting it into the next gear, due to less time required for making a shift.
Anyone else find this to be true with short shifters and a hard passes/drag racing?
Thanks,
JB
Old Sep 13, 2008 | 07:47 PM
pTr73's Avatar
pTr73
I have the MGW also (excellent shifter). But what I am about to write isnt shifter or driver related.
I somtimes get a grind out of 1st to 2nd. And sometimes completely miss 2nd. I dont think those errors are driver related. I think the grinding is from pressing the clutch pedal and yanking the shifter out of 1st gear too fast, doesnt stop the gates and/or syncs from properly aligning the gears (or something to this affect).
The missing of 2nd is when the tranny doesnt allow the shifter to go into 2nd at all, when that happens I never try to force the shift which can be bad. I guess to anybody witnessing this would think I cant shift or goofed up when in reality it wasnt me at all!
I think its really the tranny's fault and not so much ours!
Old Sep 13, 2008 | 09:15 PM
dennis50nj's Avatar
dennis50nj
try it with the shifter preloaded and just tap the clutch
Old Sep 13, 2008 | 09:23 PM
patton's Avatar
patton
St. Jude Donor '09
as long as you stay WOT i dont care how hard ya pull or push it aint coming out of gear until ya stab the clutch[healthy tranny]
Old Sep 13, 2008 | 09:33 PM
nwc6's Avatar
nwc6
I did notice that the MGW aggravated the 2nd gear grind when the tranny was cold, (2008). I had to relearn the shift, so to speak.
Old Sep 13, 2008 | 09:45 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
What would you know about clutches and shifters?
Old Sep 13, 2008 | 10:29 PM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Yes, I believe I have to pause a hair before pulling it out of gear, since it's now a shorter distance, and takes less time. A slightly more pronounced depression of the clutch just before shifting needs to happen...
Old Sep 16, 2008 | 01:42 AM
jbsblownc5's Avatar
jbsblownc5
St. Jude Donor '08
Thanks for the advice Dennis, even though it did come from an auto guy!!
I made a few pulls tonight, and did not grind once!!!
Two things were different:
1) I've done the ranger clutch fluid reservoir turkey baster thing a few times over the last few hundred miles. I had done it all along, but had not done it recently.
2) I slightly loaded up the shifter, made a more pronounced and slightly ealier clutch depression, and then pushed it into gear.
I'll try not to bust on you for driving an auto in the future, but no promises...
Thanks again!
JB
Old Sep 16, 2008 | 03:13 AM
patton's Avatar
patton
St. Jude Donor '09
Thanks again!
JB
he might bustum on you,he being an auto guy that giving advise to a gear jammer on how to shift
Old Sep 16, 2008 | 08:29 AM
dennis50nj's Avatar
dennis50nj
Thanks again!
JB
anything to help a racer brother out.
Old Sep 16, 2008 | 09:19 AM
Joe Lynch's Avatar
Joe Lynch
St. Jude Donor '09-'11
You will have to exert more arm force with the shorter throw shifter to force the synchros to work. You have lost the mechanical advantage which comes with the long throw shifter.
Joe
To Question on quick shifts with short shifter??
