I got a call this morning from Max at Cartek. The first thought that crossed my mind was "did I forget to pay for something?" But that wasn't the case, Max was simply calling to see if I was happy with the way the car is running after all the work they'd done to it several weeks ago. I suddenly thought about the driver of a Porche Turbo that I made very unhappy last night and then explained to Max that, "I'm extremely happy with the car!"
I guess I'm not used to getting a call from a shop unless something is wrong. It's nice to know there is a great shop around that cares, especially now that my factory warranty is now a moot issue.
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I've received calls and emails from Max, Julian, and Julio. All just checking in to see how everything is working. This is a valued trait in a shop. Knowing that the service doesn't stop when the job is done says a lot.
BTW...what did you have done?
Same here, they called to make sure everything was good and that i was enjoying the car and to see if i had any other questions....Very cool!
Well I didn't want to go too crazy at first, so I just went with the following for now:
Cartek Cam with supporting mods
Kooks full length headers with X-pipe and oversized cats.
Underdrive pulley
Vararam CAI
Cartek Catch Can
3.90 Gears with Heavy Duty Shaft
Dyno Tune
Ceramic Pads
Hopefully this will get the car into the 11 second bracket
