drag wheel/tire setup
Old Sep 18, 2008 | 12:48 AM
rcjustin's Avatar
rcjustin
Cruising
Default drag wheel/tire setup
What is the smallest rim size/type i can fit on a base c6 05 vette. Any 15" rims thatll fit with sliught modification or even a 16"? I want to get more sidewall in a m/t drag radial. What do you think? How much does a skinny tire up front really help? Big difference in weight transfer? Thanks
Old Sep 18, 2008 | 03:32 AM
jpee's Avatar
jpee
I doubt you can get 15" on the front, I just got an 05 A4 .. its Bone Stock, I got M/T Drag Radials 265/40x18 for the rear...
I went to Englishtown last night BEFORE I got the DR's mounted.. on my street tires, I ran 12.59 @ 111 mph... I think with a few bolt on's I'll get into the 11s in good air!
Old Sep 18, 2008 | 04:19 AM
LS1LT1's Avatar
LS1LT1
No way to get 15s on there without making some serious suspension/brake changes.
Even 16s are next to impossible to get on there without sticking out of the wheel wells too much though the 16" CCW skinnies can fit on the front with some minor grinding. And yes skinnies really do work.
17s (front and rear) seem to be the smallest diameter that can be made to fit properly.
Old Sep 18, 2008 | 01:18 PM
rcjustin's Avatar
rcjustin
Cruising
even without a z51 package in the rear you dont think a 16" rim would fit? I want to get deep into the 1.4x 60' with an a4 and 3800/4000 converter. Do most of you remove the front swaybay to cut better 60' times. Are there any other tricks to making the IRS hookup(came from solid rear mustangs) Thanks for the hlp guys
Old Sep 18, 2008 | 02:59 PM
LS1LT1's Avatar
LS1LT1
I know F-body 16" rims will not fit even on base suspension cars, though they did fit the rear of C5s with only some minor pounding/massaging.
Other 16" rims, depending on their offset and how they're stepped can be made to fit (grinding, spacers etc.) but it might look a little silly sticking out of the wheel well. I prefer 16s as well but there is just no easy way to get them on there.
Low 1.4s is possible even on 18" drag radials (and definitely possible on 17s) if you're good, it's going to take gears and some real power along with that higher stall to get it done though.
Most Corvette owners do not remove their front sway bar but yes it can help.
Old Sep 19, 2008 | 11:58 AM
FloydSummerOf68's Avatar
FloydSummerOf68
I can confirm that the 16" fbody wheels will not fit on base brakes in the rear.
I was excited that I'd get to use my old wheels...then very let down
You could make them fit with a little grinding on the caliper though I would think. The wheel only SLIGHTLY touched.
Another question; will 17" wheels fit on the front over the Z51 brakes?
Old Sep 19, 2008 | 12:02 PM
LS1LT1's Avatar
LS1LT1
Same here, I still tried even after you had posted to us about that and I too confirmed it LOL.
Yes, at least the factory/OEM C5 wheels will.
Old Sep 19, 2008 | 05:19 PM
rcjustin's Avatar
rcjustin
Cruising
guna hafta find a set thatll actually fit then. I dont mind doing alittle shaving beating at all to get what i want. lol. 16"s wil hafta do though
Old Sep 20, 2008 | 12:12 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Nope. YOu have to buy the base brake abutments (caliper mounts) and base (or c5) rotors. They fit then. That's what I run on the road course.
Old Sep 21, 2008 | 02:36 AM
FloydSummerOf68
Do we know if the 17" C5 wheels are lighter than the 18" C6 wheels? And which C5 design are you talking about? Wagon wheels, Y2Ks, Z06...?
LS1LT1 seems to disagree
If I could run 17's on all 4 corners and have them LIGHTER that would be great. A little narrower up front would just be icing on the cake.
Old Sep 21, 2008 | 04:05 PM
LS1LT1's Avatar
LS1LT1
Yes I believe they are, especially the C5 magnesiums.
Yes I do LOL...I have actually seen more than one Z51 C6 with 17" wagon wheels on them without any modifications performed to make them fit.
Unless he was actually answering the question about 16s?
Old Sep 21, 2008 | 04:39 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
17" wheels fit on BACK of a C6 Z51 fine...I've got a set on my car right now.
17" wheels DO NOT fit on the FRONT of a c6 Z51 (or any model with the bigger brake rotors) unless you put the smaller C6 or C5 brake abutments and rotors on. I run 17" C5 wagon wheels on the front of my car for road course events.
I hope that's clear....and it's based on my own real world experience. No BS.
Old Sep 21, 2008 | 06:22 PM
LS1LT1's Avatar
LS1LT1
Ahh ok, I didn't realize he was originally asking about the Z51 fronts, that I couldn't comment at all and I of course wholeheartedly trust your knowledge on these things Joe. I knew you had 17s on the back at some point and that's why I found it so puzzling LOL.
Thanks for clearing that up.
But as far as you know the C5 17s definitely should fit on the front of a base suspension C6 without any alterations correct?
Old Sep 21, 2008 | 10:07 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I had a feeling you were referring to 17's on rear vs. front as was asked.
Well, at some point the drilled bigger rotors were made available without the Z51 package.....maybe 06? If the car has drilled rotors, no go on 17's up front (without changing to base or c5 rotors and abutments). If it has solid rotors, you will be ok.
A lot of the road course guys change to the c5 rotors and abutments as c5 rotors are about $30 apiece and you go through them after a road course event or two. Much cheaper than the drilled rotors and drilled rotors are no good for track use (they crack much easier).
Old Sep 21, 2008 | 10:46 PM
LS1LT1's Avatar
LS1LT1
Yes I think it was in 2007, the Z51's slightly bigger drilled rotors became part of the F55 package as well.
Old Sep 21, 2008 | 10:53 PM
Burnin4's Avatar
Burnin4
/hijack
does anyone know if oem front c5Z06 wheels fit on the rear of a c6z06? I'm looking for an easy/inexpensive setup for drag only. thanks!
/hijack
Old Sep 21, 2008 | 11:07 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by Burnin4
/hijack
/hijack
I have heard conflicting reports that they fit with minor caliper grinding, and some folks don't have to grind. If my buddy ever takes me up on my offer and come over to test this in his new C6z I'll let you know for sure.
Meantime if you post up in the C6z section you'll get your answer for sure.
Old Sep 22, 2008 | 08:15 AM
FloydSummerOf68
Thanks for clearing that up....looks like I'll be getting 18's up front and 17's out back for a track setup.
Old Sep 22, 2008 | 08:44 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Keep us posted if you find some skinny 18" rims and tires. I haven't seen any but I haven't looked either, and I'm sure people would be interested if you found a setup.
Some of the guys I know use 17" GTO spares for the skinny rims and some M/H tires (Waverdr on the C5 forums is one guy who has that setup).
Some guys have tried (with no luck) to run the GTO spare tires down the track...but a sharp tech guy with decent eyes will put the kibosh on that as the tires clearly say "55 mph limit"!
To drag wheel/tire setup
