OnStar module location on an '08 C6??
Old 09-18-2008, 03:49 PM
nearwater
nearwater's Avatar
Default OnStar module location on an '08 C6??
Hello, guys
I need some help from you experts here.
I'm trying to find the OnStar module inside my '08 C6 coupe.
I've removed the whole center console, radio, HVAC, and the passenger glove box, but couldn't find where it's at.
I heard the Z06 has it underneath the passenger seat, but where's the module on a C6?
Any help would be appreciated. Thanks!!
Dan
Old 09-18-2008, 04:47 PM
patton
patton's Avatar
St. Jude Donor '09
VCIM in trunk /right side.under carpet floor panel :helms manual 2007
Old 09-18-2008, 04:52 PM
Chevtech
Chevtech's Avatar
Wow, you went to a lot of work for nothing.
Vehicle Communication Interface Module (VCIM) (UE1):
In the rear compartment, right rear side in compartment
tub.
Old 09-18-2008, 06:39 PM
nearwater
nearwater's Avatar
I appreciate the help, guys.
By rear compartment, did you mean the storage area with the lid on it(preferred NPP in a box location)?
Cuz I've searched, but couldn't find it.
Any tips on how to expose it?
The rear hatch floor carpet seemed like it would require quite a work to remove.
A little more help would be great!! Thanks again, guys!
Dan
Old 09-18-2008, 08:26 PM
patton
patton's Avatar
St. Jude Donor '09
the manual says remove rear carpet
Old 09-18-2008, 08:47 PM
NOCRISIS
Support Corvetteforum!
NOCRISIS's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
it is in the right side well storage,that is why if you by Ed's mild to wild,plus the nice cover,the cover has to be cut to fit and the vac line routed a bit different,
Old 09-19-2008, 01:56 AM
nearwater
nearwater's Avatar
Thanks for the help guys.
So basically, I have to remove the hatch floor carpet and the right compartment(Does it pop out?) to access the module?
I'll try to remove the carpet tomorrow. Any tips on how to not damage it while removing?
Sorry for all the annoying questions.
Dan
Old 10-26-2010, 11:31 AM
George De
George De's Avatar
Default Carpet Removal to access OnStar VCIM in trunk /right side
Can someone plz advise on procedure to remove the cargo area right side compartment lid and carpet on my 2008 C6 so I can access OnStar VCIM in trunk to install the Bluestar 2010 module.
Old 10-25-2012, 02:39 AM
miket1
8th Gear
miket1's Avatar
i am awaiting an answer for this aswell for a 2012, i ordered the bluestar, but dont want to start ripping my car appart without knowing how to do it with out damage.
Old 10-25-2012, 09:12 AM
FireRoc
FireRoc's Avatar
I had it replaced in my 2005 by the dealer as the original one was analog cellular and it had to be changed to digital cellular.
It is where it has been noted above. Given that the bin was not re-installed correctly when I got the car back, you "may" be able to gain access to it by taking the bin out. From my experience it is somewhat flexible and bendable.
Old 10-25-2012, 10:40 AM
marc8090
marc8090's Avatar
If you open the right storage bin, and pull the carpet away from the front side of the bin (pull the front carpet towards the center of the bin) you will expose the module. No need to remove the rear carpet. That being said, I believe the carpet is just laying in the trunk. Posts about guys putting in sound insulation mention it just lifting out after you pop off the two holders for the top.
Old 11-03-2012, 02:55 PM
Pittcorvette
Pittcorvette's Avatar
Here it is for a 2012 vette. Thanks markcz for the info.
http://forums.corvetteforum.com/audi...al-tranny.html
To OnStar module location on an '08 C6??
Quick Reply: OnStar module location on an '08 C6??
