Injector install ?
Old Sep 19, 2008 | 12:59 PM
Buddy A's Avatar
Buddy A
Default Injector install ?
After removing the intake. And removing the injectors. Are the seals lubed for re-install? If so, what is used?
Old Sep 19, 2008 | 02:29 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
we use dish soap. however, vaseline, gear oil also works. but, make sure you lube injector o rings
Old Sep 19, 2008 | 04:27 PM
HANNY's Avatar
HANNY
i usually use AC refridgerant oil. it seems to keep the o rings lubed over time better,,,in case you need to remove them later they will pop right out. good luck
Old Sep 19, 2008 | 05:08 PM
KB9GKC's Avatar
KB9GKC
Silicone grease will work.
Douglas in Green Bay
To Injector install ?
