TPS info
Old Sep 20, 2008 | 07:48 PM
speedwaywhite's Avatar
speedwaywhite
Default TPS info
Just back from funfest in Effingham Ill where I had an opportunity to visit with some GM engineers that were showing the new ZR1 (what a machine!)and giving ride alongs. My question was this, I want to mount some track tires on another set of wheels to use for auto cross and track events, can I run with out TPS? Answer is, no! Without TPS the speed on the C-6 is limited to 85 MPH.
Old Sep 20, 2008 | 09:45 PM
mcwire's Avatar
mcwire
Good info - thanks for posting. -- --
Old Sep 20, 2008 | 10:46 PM
KILR-RYD's Avatar
KILR-RYD
on the C6 or ZR1?
Because I have been running my car for a yr without and I have been a little() north of that afew() times
Old Sep 21, 2008 | 05:26 PM
speedwaywhite
I was told all C-6, we did not discuss ZR-1 (or Z-06)
When running w/o TPS does you DIC show any thing that you have to clear with the reset button?
Old Sep 21, 2008 | 07:17 PM
KILR-RYD's Avatar
KILR-RYD
Yup, the most annoying thing, You have a flat tire in the front right, then you click, it says you have a flat tire in the front left. Then you clear it, it says TPMs have to be serviced and then I can do something. It also shows the flat tire light on the console.
There is no such restrictions. I am tell you I have gone atleast 1.5 times that without any issues, so that is bogus. It does say reduced handling but its not telling you that the computer will reduce it, but it is warning you that, because tire is flat dont try to be O'Connell
Old Sep 21, 2008 | 07:27 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
good to know
thanks
To TPS info
