disabling traction control
I have to keep the car in "Performance Mode". If I put the car in "Traction Control Off" mode, traction control automatically re-engages and puts the car in a safety mode as soon as I start even moderate cornering.
Anybody know of a way to re-program the car?
Also, tire pressure sensor monitor issues. I have resorted to 4 Kart tires in the trunk with the tire pressure sensors mounted in the Kart tires. This allows me to switch my real tires without multiple efforts to reprogram. I still am having to reprogram the tire sensors multiple times during a track weekend? Any software solution for this problem?
Thanks much
The only thing I've heard of people sometimes having issues, is when they don't have all the tire pressure sensors. Sounds like it's related to that. There should be no need to reprogram the sensors multiple times. Are you sure they are functioning properly? If they are not getting taught correctly, then I could see them causing issues with the traction/stability control.
is your car a 2005 or is a later year?
have you time trialed or raced the car?
thank you!
So does it go into the safety mode when everything is disabled, or just the traction control? I never use the mode that only disables traction control, but it should still not change on you. But in my experience, I either use competition mode, or turn it completely off.
my tires are 305-35's R18 front and back. i dont know exact diameter but not stock obviously. car is much more competitive with this set-up (also by the way has pfadty sway bars, hypercoil springs, full roll cage in terms of suspension changes).
just to clarify, you are: able to turn the traction contol to the off setting; drive vigerously around the track without it kicking back in automatically?
thank you again - I very much appreciate input for this problem.
When you say that you disable traction control, do you mean you are only disabling traction control, or active handling as well? If active handling is still on, I could see how that would cause problems, because with the same size tires all around, the computer thinks your rear wheels are spinning the entire time.
The rears are 0.45" smaller - just under the 1/2" most people site as tolerable. The fronts however are 0.7" smaller than stock - this might be a problem - but I cannot say for sure.
Hope the info is useful.....
regarding "what am I turning off?" I am beginning to wander? I dont have the car here with me (it is at a shop) but i am going to the "third setting" which I thought was TC and AH off. I read another thread and it seems that one has to hold down the button to turn both off. I dont' remember that in my manual by I will check again.
also, another thread mentioned that pro racers ran faster lap times in competition mode - despite their seat of the pants feeling otherwise. so, it maybe better to run in competition mode. to date the car has been very competitive, running faster then much way more expensive modified M-3's in my class for example.
again thank you.
does anybody know if SCCA T-1 corvettes are still all C5 ZO6's or have some C6's made appearances yet?
again thank you.
the interesting thing will be whether or nor my lap times improve. I am beating the competition but will see if I beat them by more.
other issue: Does "Competition Mode" beat up the rear differential?
I'm not sure that I'm ready to spend 3g for an LG rear differential cooler.
The way the computer is set up you must have smaller front tires and bigger rear tires and they must be in the correct front to rear ratio.
Thanks much
Call me...I'll try to set you up right.....
If you remember, last year a race team in CHINA flew me over there to calibrate their full scale professional C6 ZO6 round track cars.
I provided stand alone harnesses and tuning services for a winning season....
NO T/C, NO ABS, NO ACTIVE HANDLING, NO TIRE PRESSURE SENSORS....
I can help you.
Chuck CoW
i have some left over toyo r8888's that were on my stock wheels. i am going to buttonwillow in a couple of weeks and will bring those along to see if the stagger makes a difference.
thank you Chuck CoW. I tried your shop on thursday and will try again during the week. it is hard for me to reach people on the East Coast during the work week from here in Arizona.
my e-mail is jiggyracing@aol.com if you can please contact me.
thanks everybody - i was close to giving up on my c6.
The 315/35/18 is very close in diameter to the stock rears (26.68" vs 26.85 stock) and a 315/30/18 would be very close to stock front diameter (25.44" vs 25.71").
Your tire pressure problems are probably because the computer isn't getting the update from a rotating sensor after xx miles @ xx speed. Best to buy another set of TP sensors so you have a set mounted to both sets of tires and get a tool to re-index the TPS, it only takes a few minutes once you have the tool.
Go to engine then traction control and hit disable.
Thats it. piece of cake.
You dont need a pro tuner.
I would imagine your car is already tuned?
If you dont have HPTuners or EFI live etc.
Ask your current tuner it takes seconds to fix.
Call me ANYTIME!~ Have no fear...I never get to go home... Don't worry about the time difference. I'm usually there till midnight or later my time. This is a busy time of year for us.
I'm traveling this week starting tuesday...But, the shop phones will forward to my cell....
Chuck CoW
i have a reprogrammer already which i use. the Kart wheels are so thin they quickly reprogram compared to the wheels on the car. between sessions, i check to make sure that they are still being "sensed"
i wish that i could run the 335's - sounds like it would make life easier and of course i wish that i could run 335's
