Weird speedometer problem while racing...
Old Sep 27, 2008 | 02:29 AM
TinSecondRice's Avatar
TinSecondRice
St. Jude Donor '08-'11
Default Weird speedometer problem while racing...
Well I took the car to the track tonight, and the couple of times that I ran I noticed when I went to slow back down that my speedometer needle was on 0 along with my HUD display. As soon as I got down to about 93 mph both the HUD and the speedometer needle would start registering again. Is this maybe because of the ET Streets that I was running on the back being a different height and at this speed they quit registering right? Any ideas?
Old Sep 27, 2008 | 07:10 AM
dennis50nj's Avatar
dennis50nj
what was your 60 ft
Old Sep 27, 2008 | 11:48 AM
TinSecondRice
Originally Posted by dennis50nj
what was your 60 ft
It was a 1.650X every single time I ran, so VERY consistent, but it wouldn't launch hard enough with the nitrous converter in it to get any better. It definitely could have hooked with a lot harder launch.
Old Sep 27, 2008 | 12:45 PM
danl72's Avatar
danl72
That is new to me.
Old Sep 27, 2008 | 01:43 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I ran ET streets and had perfect speedometer. That's not it.
Do you have aftermarket gears/rear? Maybe they forgot to hook up the speed sensor solidly, it might be a little loose. I've seen it happen. Do you have the check engine light on? Can you read the codes?
Old Sep 27, 2008 | 03:17 PM
dennis50nj's Avatar
dennis50nj
thats why, it seems like all a4 speedo doesnt work on great 60 fts untill you let off the gas, if you launch slower or hit it once moving the speedo works.
Old Sep 27, 2008 | 03:18 PM
TinSecondRice
I am pretty sure the gears are the stock 3.15's, but the rear may have been replaced. The car was a repo when I bought it and it had a century upgraded transmission in it, so I am not sure if they built the rear while they had all that out or not. Is the speed sensor somewhere that I could access it to fix the problem if its lose? There is no check engine light on...
Old Sep 27, 2008 | 05:37 PM
Evilways's Avatar
Evilways
you out ran the speed of speed.......
Old Sep 27, 2008 | 05:57 PM
TinSecondRice
Thanks! That is probably all it is then, I was just making sure there wasn't anything wrong with it
Old Sep 27, 2008 | 06:44 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Yes the speedo wire is on top of the diff, toward the right side. If a trans was replaced that clip was removed. Just make sure all connections on the diff are tight.
Dennis are you kidding about tht 60ft comment? I've NEVER had my speedo not work...nor have my buddies...except when we've forgotten to plug in the speedo. You pullin our leg?
Old Sep 27, 2008 | 06:48 PM
dennis50nj's Avatar
dennis50nj
mine has done it since ever since i started getting great 60 fts with the converter, my gears were stock, i know a few gto goes have the same problem, and it is exactly what evilways said, you out ran the pickup on the start. once it is moving slower it picks it up
Old Sep 27, 2008 | 07:11 PM
AirBusPilot's Avatar
AirBusPilot
My twin turbo 05 GTO would always do that if I did a big burnout.
Old Sep 29, 2008 | 09:24 AM
AintQik's Avatar
AintQik
I seriously hate you auto guys... 1.6x short times. Geeze.
Old Sep 29, 2008 | 10:32 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Practice! You can do it. Just gotta walk that clutch out and let it take the abuse and get the car moving.
Old Sep 29, 2008 | 11:14 AM
dennis50nj's Avatar
dennis50nj
nope Joe its true it happened after the converter the trans has been replaced and converter re clutched wires checked and it still does it only on good sixtey fts, i have talked to 10 gto guys with the same problem
Old Oct 29, 2008 | 01:27 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Any resolution to this? A friend of mine just put in gears in his 05 (using an 06 case) and his speedo drops to 0 at 19 mph...then pops up to read normally after 3 minutes....weird...I've never had that problem with my 05.
Old Oct 29, 2008 | 03:11 PM
kbobk's Avatar
kbobk
I have had this same thing happen to me too. I have not got it figured out yet. It all started after I had gears put in. It is infrequent, random and seems to only happen when I am running the car hard in 4th or 5th. The speedo will pick back up when I get out of the gas. Very strange and bugging the heck out of me.
To Weird speedometer problem while racing...
Old Oct 29, 2008 | 03:17 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Hmm.
What year is your car, and do you know what year rear end they used in your car? In my friend's case it's an 05 car and an 06 rear end case. I'm wondering if there is a difference in the reluctor wheel that the vss is not getting a good reading at times during acceleration...
Old Oct 30, 2008 | 08:55 AM
kbobk's Avatar
kbobk
Hmm.
My car is an 08 and I was told they used an 08 rear end since the 08 rear was different from prior years. My best guess is that there is a loose connection somewhere. I have had the service active handling message come on one time when the speedo dropped to zero too.
Old Jan 30, 2010 | 12:14 PM
SnowyATX's Avatar
SnowyATX
I had this happen to me on the street the other day while driving through the neighborhood....and no I wasn't racing or getting on it....just cruising.
