Having BB Fusion System Installed, Quick Questions...
Old Sep 30, 2008 | 12:19 PM
tsanford405's Avatar
tsanford405
Default Having BB Fusion System Installed, Quick Questions...
Hey, I am receiving the Billy Boat Fusion system in tomorrow with the Mild2Wild system. Because I don't have the facilities to install this myself I will be forced to have it done. I have a couple quick questions...
1. Does this system come with complete instructions for install? I found some incomplete ones on their website, but nothing too thorough.
2. How long should this take someone to install overall? The place I am looking at charges $70/hour for labor.
3. Does anyone know a reputable Corvette place in Kansas City to have them installed?
4. Is there anything I should be certain to mention when dropping everything off?
Thank you! Can't wait!!!!!
Old Sep 30, 2008 | 03:29 PM
VETFEVER's Avatar
VETFEVER
You should look up a Forum Member named "Bub"
He lives in KC and had the BB's on his C6 coupe at one point.
Cheers
Old Sep 30, 2008 | 07:50 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
ANS: Yes, much more detailed then on the web site
ANS: If they know what they are doing 1hr
ANS: Can't help with that one
ANS: I would show up before the car is off the lift to be sure you are happy with the alignment
Old Sep 30, 2008 | 10:08 PM
bub's Avatar
bub
Thomas,
Looking forward to the install.
As noted in my e-mail, if you can scan and send me the instructions ahead of time (particularly on the B&B preferred manifold vacuum connection location and routing) that would be good. The rest I've done before, at least three times or more...went thru several exhausts on my coupe...leaving my Z alone for now .
I also want to get a real close look at your M2W and compare it to the Logisys RM02 remotes that I've been using on my own cars.
-CKB
PS: Jack - how's your system doing? All well?
Old Oct 1, 2008 | 12:11 AM
C5pilot's Avatar
C5pilot
I think 1 hr is pushing it. Opening the vaccum port, running the tubing, wiring, drilling and mounting the control unit in the fender will burn as much time as installing the actual exhaust, probably more. However, people tend to work faster when it's someones elses car. My buddy and I took our good 'ol time on my car and it took a couple of hours including an oil change.
Old Oct 1, 2008 | 06:40 AM
Pipedreams's Avatar
Pipedreams
Originally Posted by bub
Thomas,
Revised quote = 5+ hrs Only joking you’re in good hands
Old Oct 1, 2008 | 09:41 AM
tsanford405
Thanks for all the info! BLUE HVN, thanks for tellin me about Bub, I talked to Bub and he has agreed to help me out with the install. This forum has been awesome so far, and just got that much better! It's great that people are willing to help out new guys so openly!
I look forward to the install and learning all about the particulars of it. I will also be very interested to see under the car since I haven't had the chance to get under there yet!
Also, does anyone have the supplied instructions in PDF form by any chance?
Thanks!
Old Oct 4, 2008 | 05:58 PM
bub's Avatar
bub
Some pics from today's install...indeed, 1 hr was a bit optimistic.
Tom can elaborate.
In the end all went well, just took longer than anticipated. Getting the vacuum tap on the back of the manifold is impossible without removing manifold. See improvised vacuum booster "tee" solution pictured in next post below.
Old Oct 4, 2008 | 06:00 PM
bub's Avatar
bub
Old Oct 4, 2008 | 11:55 PM
bent's Avatar
bent
how's it sound????
Old Oct 5, 2008 | 06:03 PM
tsanford405
The sound is AMAZING. The loud setting is mind numbing after a while I have to admit, but that is what the switch is for. I love it! bub helped out TREMENDOUSLY! Great guy, and I had a great time installing everything. Thanks bub for helping me out and letting me use your lift!
Long install, but everything was done right and everything looks great!
Old Oct 5, 2008 | 09:46 PM
bub's Avatar
bub
Old Oct 5, 2008 | 10:55 PM
C5pilot's Avatar
C5pilot
Told you so.
Not impossible, but a Royal-PITA for sure. I was able to use a pair of curved needle nose pliers and lucked-out getting the tube on the port.
PS. There are warnings about attempting to use vacuum from the brake port.
Old Oct 5, 2008 | 11:23 PM
tsanford405
Default Vid
Here is the aftermath!
http://www.youtube.com/watch?v=l1tdfchxoZI
I understand the concerns about the brake line, and I will eventually decide to go through the hassle of putting it on the "proper" vacuum outlet. We put together a VERY solid piece that I am confident will hold up very well. For now it works very well. I just got it programmed to the homelink tonight, very cool! My dad loves it (I think he's a little jealous! )
Set off my first car alarm today too!
Old Oct 6, 2008 | 05:01 PM
tsanford405
Here are some more pics of the install and product in case people are interested. Pretty awesome stuff! I can't imagine a better exhaust system. If anyone has any questions on the install feel free to write me a note!
Before...
After...
Old Oct 7, 2008 | 11:34 AM
BBExhaust's Avatar
BBExhaust
Premium Supporting Vendor
And many more to come!! Hope you enjoy the system.
Old Oct 7, 2008 | 03:11 PM
VETFEVER's Avatar
VETFEVER
Chris
Looks like you continue to lead the Corvette Community with your time and generosity - luv it
My car is doing very well - got some BBS's for it which look great, and am adding a full-width racing spoiler and those GM splash guards.
Note my new name "VETFEVER JACK" - VETFEVER was taken on the Forum, so I added the Jack part...
Hope the Z is fully broken in and running fine - I am sure it is
Take care sir
To Having BB Fusion System Installed, Quick Questions...
Old Oct 7, 2008 | 03:13 PM
VETFEVER's Avatar
VETFEVER
Thanks!
You're welcome - Chris of course did everything....
Old Oct 7, 2008 | 08:55 PM
bub's Avatar
bub
Hey Thomas, all I get are red X's on the pics you posted...
OP: Agreed, back manifold tap is best spot; however, I didn't have a set of curved needle nose to try to get at it with...left it readily removable/changeable for Thomas to try again when he feels like taking on the frustration of it. Also, back manifold booster tap and prescribed vacuum tap are side by side, with the only difference being the volume of the booster vac. line itself. The vacuum check is at the booster. I knew we would be defending this one...
Same vacuum location more or less, and brake booster is where S/C's are tapped for blow-off valve and boost gage, so it should be just fine.
Additionally, if one loses vacuum, they do not lose brakes, just have to put some muscle into it, just like a failed booster diaphragm feels like, or a like 1963 farm truck (similar brake feel - I've driven them both)
Jack - Z just passed 1k miles coming back from Funfest in Effingham a few weeks ago...starting to feel like the S/C did, plus cooler temps really bring out the torque beast. I owe Thomas a ride and I told him I want to drive his paddle shifter just to be able to say I have driven one...
Old Oct 8, 2008 | 10:31 AM
tsanford405
Hopefully that fixed the picture problem!
I should have that nut/bolt for you soon. I will let you know when I get it and I can swing it on by and let you try out the paddle shifter.
Can't wait to ride in the Z so that I can try and keep myself from buying a S/C for a while. I did call the finance department and they said that I can get a prorated refund for the extended warranty I purchased at any time, so that is good news. I may keep it just in case I have problems with other things like window motors, etc.
Next... IPOD connector, Intake, Spacer... then who knows!
