NAV System
Old Oct 3, 2008 | 09:17 AM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
Default NAV System
123
Old Oct 3, 2008 | 09:57 AM
Walt White Coupe's Avatar
Walt White Coupe
Step One: Make sure you have set the proper region
Step Two: Read the manual
Old Oct 3, 2008 | 01:00 PM
jam313's Avatar
jam313
Same issue when I bought my 05 used. It was a local Texas car, yet the region was set to the Northeast US.
Make sure the map of the US has your region highlighted.
Old Oct 3, 2008 | 01:38 PM
mdz06vetter
already had/have done the obvious - MD and PA are in the same region, and yes, I did check that it was the correct region - and the manual is not very helpful, in my not so humble opinion - in fact it is one of the worst manuals I have seen as far as being helpful!!!! - this should be as intuitive as the Garmin handheld -
BTW - don't post tech questions unless the "mighty fine manual" can't help me out, which it can't
Old Oct 3, 2008 | 09:10 PM
mdz06vetter
Default Now, the Rest of the Story......
turns out it was multiple issues - didn't know there was TWO DVDs and wrong DVD was in the tray - second issue, was system needed to be updated, and finally, the DVD marked #1 that was supposed to be with the car had a huge scratch on it and it couldn't be read! all is well now -
actually used several times "locally" to get me around DC today and worked flawlessly!!!!!
Old Oct 3, 2008 | 09:12 PM
johnodrake's Avatar
johnodrake
Moderator
Glad it worked out for ya. I am quite happy with mine.
To NAV System
