LS3 Clutch Fluid Bleeding Help
Old Oct 5, 2008 | 03:32 PM
BlueFish81's Avatar
BlueFish81
Default LS3 Clutch Fluid Bleeding Help
Can someone please help me with the LS3 Manual Transmission Clutch bleeding process? I can't seem to find the bleeding valve for the clutch fluid. I purchased the bleeding valve extension and wanted to install it so I removed the driver side header and from what I see the bleeder is not in the same location as the LS2. Someone please help ASAP
Thank you.
Karn
Old Oct 5, 2008 | 07:47 PM
HANNY's Avatar
HANNY
Thank you.
Karn
i have never had one apart but i has to be the slave itself,,,maybe hidding toward the back or has a cover over it? good luck
Old Oct 7, 2008 | 09:00 PM
ALS 08's Avatar
ALS 08
Default Saw this comment on another thread
Of course bleeding the clutch on a C6 is a tremendous amount of work since the bleed screw cannot be easily accessed. If I remember correctly, the entire rear-end / tranny and torque tube must be lowered to access the bleed screw. It's a serious headache.
To LS3 Clutch Fluid Bleeding Help
