Who built your a4?
Old Oct 8, 2008 | 06:29 PM
TinSecondRice's Avatar
TinSecondRice
St. Jude Donor '08-'11
Default Who built your a4?
Well I took my car in to get the transmission flushed, 2 weeks later drive and overdrive went out. I put it on the lift today and checked the fluid and it was 3.5 quarts low!!!! I told them 3 times to make sure they put enough fluid in it because it had a transmission cooler on it and a b&m pan so it would take some extra, apparently they did not listen! So now I am faced with having to get the transmission rebuilt. It has a transmission from Century transmission in it right now, not sure what stage as it was already in the car when I purchased it. Any suggestions on who to have build it? My dad is ASE certified for automatic transmissions so I would prefer to just buy the parts and put them in myself if anyone knows a shop that sells the parts? THANKS!
Old Oct 8, 2008 | 10:33 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Man, that's crazy. It sounds like they had never done a vette before. When I did mine, I put fluid in until it came up to the fill hole, then started the motor and filled it the rest of the way. It held almost 2 gallons and I don't have a cooler or an oversized pan. It almost sounds like they just filled it up until it came up to the fill hole and didn't start it and finish filling it. I hate to hear that for you.
