Need help ASAP.. SPACERS
Old Oct 18, 2008 | 11:59 AM
james1990's Avatar
james1990
Default Need help ASAP.. SPACERS
i am doing the rear zo6 conversion next week and untill i find a set of rims i will be keeping the stocks on there for a bit..i know some people put spacers on..which size spacers should i use to fit the zo6 fenders correctly?
Old Oct 18, 2008 | 12:09 PM
Garys08Z06's Avatar
Garys08Z06
St. Jude Donor '12, '15
I used 1.7" spacers.
Old Oct 18, 2008 | 12:21 PM
stocksuspension's Avatar
stocksuspension
has anyone broken wheels studs due to the use of spacers?
Old Oct 18, 2008 | 01:29 PM
Kent1999's Avatar
Kent1999
I used 2 inch spacers. 1.7 inches is probably optimal, but all I could find were either 1.5 or 2 inch.
Your studs should be fine. Whether you have a z06 wheel or a c6 wheel with a 2 inch spacer, you have about the same distance between the hub mounting surface and the outer edge of the rim, so the load on the studs is about the same.
Old Oct 18, 2008 | 09:06 PM
RanGer498's Avatar
RanGer498
what brand spacers are you guys using ?
Old Oct 18, 2008 | 11:44 PM
cmonkey713's Avatar
cmonkey713
Yea'h what kind and where do you get them?
Old Oct 19, 2008 | 02:10 AM
james1990's Avatar
james1990
Old Oct 19, 2008 | 05:23 AM
THECRAIGMEISTER's Avatar
THECRAIGMEISTER
Most of the wheel suppliers have them. Check with some of the forum sponsors. I remember seeing them on some of there sights. I think mine are only one inch but I already had 1" wider wheels with 305 Nitto Invo's on the back. Looks about right till I can get the wider rims and run the 345's.
Old Oct 19, 2008 | 07:14 AM
Garys08Z06's Avatar
Garys08Z06
Bought mine, 1.7" spacers, from Skulte Performance Design. In a couple of weeks I will be selling my 1.7" spacers and my stock 05 chrome wheels that were widened to 19x12" by Weldcraft Wheels in case somebody is interested. Just PM me if interested.
To Need help ASAP.. SPACERS
