Michelin Pilot Sport Cup
Old Oct 22, 2008 | 05:29 PM
Garys08Z06's Avatar
Garys08Z06
St. Jude Donor '12, '15
Default Michelin Pilot Sport Cup
Has anybody used these tires on all 4 wheels on a C6 Vette for normal spirited driving on the road? I received a set of these tires as a gift, sizes 265/35/18 and 345/30/19 , for my 05 widefender Vette and was wondering how they "react" to normal road conditions. Any comments are appreciated, thanks.
Old Oct 22, 2008 | 05:59 PM
Minkster's Avatar
Minkster
MPSC's are very heat sensitive and need to be hot to work correctly, otherwise they are very slick and unpredictible when cold if pushed. I have used them as track tires (on both C6 and C6Z) so I can drive to-from the track. Once hot, they are excellent track tires, but I seriously doubt you will get them to working temp on the street. I would advise against street use, especially in your part of the country now and through the winter. When I have driven them on the street, they are very loud/harsh and tend to "tramline" quite a bit.
Old Oct 22, 2008 | 07:05 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
...and they'll throw tons of rocks (in street use).
Old Oct 22, 2008 | 07:13 PM
LS3FORME's Avatar
LS3FORME
They are dot race tires, good to drive to and from trackdays, bad for normal driving. Usually used as a dedicated track tire ,tread wear about 80, not the stickest ,but gt3rs 911s run them as stock factory tires.
Old Oct 23, 2008 | 09:21 AM
Garys08Z06's Avatar
Garys08Z06
I read the TireRack review on these tires and was surprised that they are used original equipment on th E92 BMW M3 and the Porsche Turbo and GT2. I am going to install them and give them a try since nobody seems to have the Michelin PS2 in the 345/30/19 size and they are on backorder. Plus they are new and "FREE".
Old Oct 23, 2008 | 10:11 AM
Minkster's Avatar
Minkster
These are not OEM tires on the E92 M3 or Porsche Turbo. GT3RS and GT2 do come with them as an option since these cars are heavily track oriented. They did come as OEM on the E46 CSL M3 as it was also a track oriented vehicle, but was only offered in Europe.
You need to read the Tire Rack reviews for Corvettes and you will see they are tricky tires. Be carefull .
Old Oct 23, 2008 | 10:48 AM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
I agree, I run them and when cold, you might as well be running on rims. They are a very good tire for the summer and it doesn't take thaaaat long to heat them up. Expect to lay down $2K about 3 times a year for a new set though.
Old Oct 23, 2008 | 11:43 AM
beanfree's Avatar
beanfree
I had them on my e46 330i supercharged BMW. Great tires. Very sticky. Not bad in rain either (they were probably at 1/2 tread and I thought the grip was better in the wet than my Bridgestone RE 01R's).
They do throw up a lot of stones crawling around a parking lot. People behind you will get sandblasted.
They run slightly wider than normal tires.
They last all of 3000 highway miles with a little spirited driving. Hope that helps.
Old Oct 23, 2008 | 01:37 PM
eric7197's Avatar
eric7197
Cruising
I just bought two of these tires for the rear of my Z06. I am running just under 600 rwhp. I agree with the posters. They seem real loose and according to the reviews hydroplane real easily if you are out when it rains. I will probably not buy these tires again when these wear out. They were more expensive then some of the other tires out there too.
Old Oct 23, 2008 | 11:09 PM
shifter77's Avatar
shifter77
LOVE THEM ON MY ZO6
Old Oct 23, 2008 | 11:49 PM
Vito.A's Avatar
Vito.A
Great track tire, but the PS2 is a better choice for daily driving.
Old Oct 24, 2008 | 06:38 AM
Garys08Z06's Avatar
Garys08Z06
I appreciate everybody's comments and since I am lucky enough to drive 500 miles in my Vette a year, I am going to install these tires and see how they perform. I have not driven my Vette since May and the lull in the economy might be beneficial to me to get back home and work on it and driving it. Stay Tuned!!
Old Oct 24, 2008 | 06:24 PM
evansaut's Avatar
evansaut
for anyone using non run-flats, there is a spare tire kit available @ www.VetteSpare.com
Old Oct 24, 2008 | 10:45 PM
EVILNESS's Avatar
EVILNESS
These tires suck dont waste ur time just selling them to me ill take the hit on em.
R/
To Michelin Pilot Sport Cup
