cammed ls3
Old Oct 23, 2008 | 09:19 PM
TodLS3C6's Avatar
TodLS3C6
Cruising
Default cammed ls3
how much lift/dur @ 50 can u put in a ls3 with 30 thou shaved off the heads?
Old Oct 24, 2008 | 08:20 AM
Jon@RedlineMotorsports's Avatar
0Jon@RedlineMotorsports
Former Vendor
the intake side is where you have to be careful on this motor
you need .080 PVC intake, .100 PVC exhaust.
i would say no more than low 230s inake, low to mid 240s exhaust
rule of thumb: ALWAY MEASURE, MEASURE, MEASURE PVC !!!
lift doesnt matter
Old Oct 24, 2008 | 12:03 PM
MarkRx's Avatar
MarkRx
while were talking about cams for an ls3, is there a plug and play cam you can stick in this engine to give it a little more power and sound without touching anything else? i see these "cam only" posts, but they also include rollers, different springs, a tune, etc.
Old Oct 24, 2008 | 11:12 PM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
When people say "cam only", they're referring to the cam being the "only" interior engine modification. Of course, to properly install and account for a larger cam, its STRONGLY recommended that you upgrade the valvetrain accordingly. The 'rods, seats, springs, retainers, etc. are considered one and the same with the cam. Its part of a complete swap.
"Cam only" is something heard in regards to the first real round into non-bolt-on mods after the usual bolt-ons have been completed, i.e. intake/ehxuast/tune. All of which are necessary to properly facilitate a cam-swap. You could swap cams without upgrading the intake and exhaust tracks, but it would be pointless. The cam is there to push more air through the engine. You'd be choking it by not allowing it to breath, negating your cam purchase.
If someone told you they were remodling their house, and the first round was "bathroom only", you wouldnt assume they simply remodled just the basic structure that forms the bathroom. It would mean a new shower, sink, cabinets, floor tiles, possibly toilet/plumbing, lighting, etc. A "bathroom only" remodel. Its a pacakage deal.
If that helps.
Old Oct 25, 2008 | 12:56 AM
biggn's Avatar
biggn
Default re
the gm hot cam claims 50 hp. that sounds good to me.
Old Oct 25, 2008 | 09:05 AM
GenuineSurprize's Avatar
GenuineSurprize
just put a cam in my ls3 and all i can say is..........DAMN! its worth it 100 percent.
Old Oct 25, 2008 | 09:57 AM
MarkRx's Avatar
MarkRx
well said slick... it makes sense to me, but i'm wondering if there is such a cam out there, like the "gm hot cam" which some say has been out for ever and is not well suited for the LS3, yet it's an option for the LS3 giving it 480hp. what else do they change when they add this cam from the factory? the intake remains the same. I'm wondering if it's worth it to have GM swap cams so it stays under warranty.
Old Oct 26, 2008 | 11:07 AM
TodLS3C6's Avatar
TodLS3C6
Cruising
off the topic, but when u buy a cam for the ls3, what all do u need besides the obvious? i know u need springs and pushrods, but i see people changing oil pumps and timing chain.
Old Oct 30, 2008 | 12:31 AM
TodLS3C6's Avatar
TodLS3C6
Cruising
ttt
Old Oct 30, 2008 | 08:42 AM
GenuineSurprize
no need for any of that
To cammed ls3
