Intake Advice
Old Oct 23, 2008 | 09:23 PM
Buster1's Avatar
Buster1
Default Intake Advice
Which CAI is the cheapest, most expensive? Which is the best and WHY??? Which one gives the best performance? Are they tough to install? Help with a big decision...please.
Thanks!
Old Oct 24, 2008 | 06:12 PM
MSC6's Avatar
MSC6
Thanks!
Do a search here and in the C6 general section and you will have all the answers you want. There is usually a war started between which is best. Some don't believe they work at all. Good luck.
Old Oct 24, 2008 | 06:20 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
VR is the best IMHO.
Old Oct 24, 2008 | 06:40 PM
haljensen's Avatar
haljensen
And don't believe all advertized CAI's are really CAI's. Some Manufacturers advertize a filter/filter box as a CAI.
If the install doesn't require cutting the radiator shroud it's a HAI (Hot Air Intake) just like the stock filter/filter box.
Old Oct 24, 2008 | 07:07 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Vortex Rammer, Honker, and Vararam are the only true (cut the shroud) Cold Air Intakes.
Old Oct 24, 2008 | 08:21 PM
jxhunte's Avatar
jxhunte
I had your same questions. I searched this Forum and found a wealth of information. I believe all true CAI are very close to one another when analyzing performance. I went with BPP's Vortex Ram Air CAI. Liked the look, quality of the unit, performance and ease of installation. Do a search and have fun with this upgrade over stock.
Old Oct 25, 2008 | 07:00 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I also installed the BPP Vortex Rammer. I liked the product quality and the filter sits higher from the ground than the Vararam, so there is less chance of water intake. The installation was fairly easy and BPP's website has an installation instruction video that was helpful.
Old Oct 26, 2008 | 11:43 PM
Buster1's Avatar
Buster1
Thanks guys! Is a tune following a CAI install REQUIRED?? Or is it just preferred? IE...can I hurt my car by installing a CAI and not tuning it?
Old Oct 27, 2008 | 01:38 AM
LS1LT1's Avatar
LS1LT1
Vararam Snake Charmer =
Old Oct 27, 2008 | 01:59 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
A tune is not required but some recommend it to maximize the CAI benefit. I installed The BPP Vortex Rammer and didn't do a tune and the car ran great. The computer will adjust to the increased air flow after some miles of driving, somewhat of a self tune.
To Intake Advice
