ls3 ewp
Old Oct 23, 2008 | 09:44 PM
TodLS3C6's Avatar
TodLS3C6
Cruising
Default ls3 ewp
does the meziere elec water pump fit these cars? thanx 4 help n advance.
Old Oct 23, 2008 | 09:52 PM
blackfd's Avatar
blackfd
is this even worthwhile?
Old Oct 23, 2008 | 10:17 PM
TodLS3C6's Avatar
TodLS3C6
Cruising
please............. if you dont know, why post? ive got a free one for whatever that matters. ive had em on ls1s and my ls2 camaro has one. but the pump looks a little different on my vette. please someone chime in that knows.
Old Oct 24, 2008 | 12:04 AM
TodLS3C6's Avatar
TodLS3C6
Cruising
ttt someone must know
Old Oct 24, 2008 | 07:50 AM
EuroRod's Avatar
EuroRod
I've had the Meziere pump on my ProCharged 2005 for about 20 months with zero issues. The car is also equipped with a Ron Davis radiator, and big oil cooler. I have the pump wired into the accessory circuit and I can run the pump without the engine running. The car runs very cool with this system. On days when the outside temp is below 80 degrees, the car will run about 90 degrees above this temp. When the outside temp get hot, with temps in the 90's the car will run 100 degrees above this temp. Oil temps usually run 10 degrees above the coolant temp. I've never seen coolant temps above 210 and oil temps above 220 with this system. The car is not tracked. These are street numbers.
To ls3 ewp
