C6 clutch fluid level
Old Oct 24, 2008 | 09:10 PM
gjones122's Avatar
gjones122
Cruising
Default C6 clutch fluid level
Hey all.. i have an 07 C6.. 11000 miles. the clutch fluid level, when i checked it today, is right on the "low" line. anyone know if this is ok, or normal, or cause for alarm? the clutch feels perfect. thanks gjones122
Old Oct 24, 2008 | 10:43 PM
loubob57's Avatar
loubob57
I'd recommend sucking out the old fluid pouring in new then pumping the clutch 15-20 times. Repeat once or twice. Being very careful not to get any on the paint ...
I did this at 10,000 miles but I don't remember the level being low. The old fluid is probably kind of brown which may mean it has absorbed some water.
Old Oct 25, 2008 | 02:38 PM
nwc6's Avatar
nwc6
Read through this procedure developed by CF member Ranger. Pretty good write up. I change my fluid every 1000-1500 miles..Once you get all the necessary "tools" its easy..
http://www.rangeracceleration.com/Clutch_Care.html
To C6 clutch fluid level
