Shock Replacement
Old Oct 26, 2008 | 04:54 PM
timd38's Avatar
timd38
Default Shock Replacement
I have had a set of Bilstein Shocks sitting in the garage for a few months now. I decided to install them yesterday. After spending an hour trying to figure out how to get the fronts compressed and out, I did a forum search. The 32 tie rap version did not look like the answer, so I kept looking.
The Pfadt version is the best, just remove the upper control arm. Real simple when you do it that way. Also the upper control arm doesn't impact alignment since it bolts to the frame.
Old Oct 26, 2008 | 09:09 PM
CMY SIX's Avatar
CMY SIX
so what did you think of the bilsteins?
Old Oct 26, 2008 | 09:19 PM
STRAFER's Avatar
STRAFER
breaking the upper a arm is the easy way to do it. i went with fsd's. very good, road quality and handling improved. only negative is $700+ price. how are the bilstiens
Old Oct 26, 2008 | 09:40 PM
timd38's Avatar
timd38
A little stiffer than the Z51, but I like them.
Old Oct 27, 2008 | 01:09 PM
SvetteC6's Avatar
SvetteC6
Default Chain Method
I used a section of chain. I compressed the top and slid the chain link over the top of the shock then I compressed it again and slid the bottom link over the lower end of the shock. There is no way that was going to break and it came out easily.
Old Oct 27, 2008 | 06:49 PM
timd38's Avatar
timd38
I like that!
To Shock Replacement
