Fire Ext needed???
Old Oct 27, 2008 | 11:35 PM
dsp300c's Avatar
dsp300c
Default Fire Ext needed???
I am about to do a roll bar to conform with the NHRA rules. Is a fire extinguisher required for 11.49 or quicker? Some say I need one and some say I don't. I looked around and couldn't get an answer.
Andrew
Old Oct 27, 2008 | 11:46 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I have on in my other car. They're cheap and could prove invaluable.
San
Old Oct 28, 2008 | 12:00 AM
keyplyr's Avatar
keyplyr
Old Oct 28, 2008 | 12:01 AM
dsp300c's Avatar
dsp300c
does it need to be a particular kind? i found some cool black chrome fire ext with the jake skull c6r logo...also does it need to be placed in certain spot?
Old Oct 28, 2008 | 01:42 AM
keyplyr's Avatar
keyplyr
I would suggest getting a "clean agent" type. Leaves no residue on your engine should you ever need it. Make sure it has a large enough volume to be effective. 2 1/2 lbs is the common size, but if I buy another one I might go larger just to be prepared. I have seen people's cars bun while they stood helpless (more than once.)
..does it need to be placed in certain spot?
Several sports are common. As shown in my above post, on floor in front
of passenger seat mounted to seat rails with a bracket. Another place is on your roll bar, but I'd be hesitant to suspend it up in the air like that; could become a projectile in an accident.
Old Oct 28, 2008 | 10:22 AM
dsp300c's Avatar
dsp300c
cool..thanks for the info...
Old Oct 28, 2008 | 11:00 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
A fire extinguisher is not required but is recommended per the 2008 rule book, unless you are running in the higher classes. It must be securely mounted and cannot use flip open type clamps.
Old Oct 28, 2008 | 11:42 AM
dsp300c's Avatar
dsp300c
flip open type clamp?
Old Oct 28, 2008 | 12:27 PM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
like the ones in the picture this thread
Old Oct 28, 2008 | 12:35 PM
dsp300c's Avatar
dsp300c
ah...so i need to buy an actual bracket...like this one?
http://www.pfyc.com/mm5/merchant.mvc...&a_aid=froogle
Old Oct 28, 2008 | 12:39 PM
Bad06vette's Avatar
Bad06vette
Wow andrew, another noob thread.... way to go.
Old Oct 28, 2008 | 12:54 PM
dsp300c's Avatar
dsp300c
haha....did it just for you...took you long enough to find my thread and post up about it...i am disappointed...lol
even though it is a simple question you have to ask questions to get answers
Old Oct 28, 2008 | 01:05 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
I think a fire extinguisher is a must in any car. A good friend and fellow CF member, Dominic (DOMSCOM) experienced the horror first hand that will always keep an extinguisher in his car, as there will always be one in mine. Hopefully, no one will ever need it.
Fire Thread
Old Oct 28, 2008 | 01:19 PM
dsp300c's Avatar
dsp300c
wow...i will get one for sure...now i just have find a non red one with a either a seat or roll bar mount
Old Oct 28, 2008 | 01:56 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
I removed mine
Old Oct 28, 2008 | 02:00 PM
dsp300c's Avatar
dsp300c
Originally Posted by LS2-Zomb!e
I removed mine
haha
To Fire Ext needed???
