Changing CAI Question…
Old Oct 29, 2008 | 11:32 PM
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Default Changing CAI Question…
I have decided to change from a Vararam to a Blackwing CAI.
While I have a replacement radiator shroud, when I removed the Vararam and looked at the shroud with the cutout, I began to wonder if there would be any problems if I left the Vararam modified shroud in place instead of installing the new shroud.
Would the increased airflow to the intake be beneficial or would the decreased airflow directed to condenser/radiator possibly cause problems?
Thanks for all comments or recommendations.
Old Oct 30, 2008 | 07:09 AM
Mike02z's Avatar
Mike02z
The only issue will be more dirt in your engine bay. Other than that you will be fine.
Old Oct 30, 2008 | 09:55 AM
haljensen's Avatar
haljensen
The Blackwing is NOT a CAI unless you cut the shroud.
Old Oct 30, 2008 | 12:11 PM
LJD51's Avatar
LJD51
Hmmmmm, maybe I will cut the new shroud with a smaller opening to accomodate the size and shape of the Blackwing which should still increase the air flow but let less dirt into the engine.
I will post pics of the process and final results.
Thanks for the responses.
Old Oct 30, 2008 | 05:52 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
If you don't mind revealing, why are you making the switch?
Old Oct 30, 2008 | 09:12 PM
Paratrooper307's Avatar
Paratrooper307
You shouldn't have any cooling or other issues. And I would also be interested in knowing why you are switching. Very happy with my Vararam.
Old Oct 30, 2008 | 09:18 PM
LJD51's Avatar
LJD51
I had a custom hoodliner painted and the silicone coupler was rubbing the paint off part of it; the Blackwing air bridge is lower than the Vararam air bridge.
To Changing CAI Question…
