all xo-pipes the same?
Old Oct 30, 2008 | 02:10 PM
kleiner3956's Avatar
kleiner3956
Default all xo-pipes the same?
Before i spend the money to buy a used corsa exhaust system figured better be sure it fit. So far ive figured out that all corsa sport catbacks are the same part # wether manual or automatic
The question is,, is the x-pipe different, the only corsa x-pipe ive found states at bottom ONLY fits 2005+ manual cars. Which mine is, however the guy took this system off his 06 automatic with paddle shift.
Old Oct 30, 2008 | 02:18 PM
kleiner3956
another quick question will the corsa x-pipe hook up too kooks headers w/ cats ?
Old Oct 30, 2008 | 03:25 PM
AfrBurNr's Avatar
AfrBurNr
well the trick is kooks headers have a 3 inch collector and then to fit to stock C6 cat-back size they reduce them to 2.5 in the mid pipe. The best bet is to go for the mid pipe and cat back for a Z06 it all stays 3"
I'm going with 1 7/8th to 3" headers with a high flow catted 3" to 3" X pipe and a corsa sport 3" Z06 cat-back FYI
but if u dont plan on 500+ rwhp go with the 1 3/4s headers
To all xo-pipes the same?
