Help please
Let us know if it works for you too.
Service Information C6 Chevrolet Corvette | Corvette (VIN Y) Service Manual | Document ID: 2182040
#08-08-67-013A: Snap, Pop or Rattle Noise from Lift Off Roof Panel While Driving (Replace Front Lift Off Roof Panel Handles and Lube) - (Aug 25, 2008)
Subject: Snap, Pop or Rattle Noise From Lift Off Roof Panel While Driving (Replace Front Lift Off Roof Panel Handles and Lube)
Models: 2005-2009 Chevrolet Corvette
with Removable Clear Roof Panel (RPO CC3), Removable Sun Roof Panel (RPO CF7) or Dual Removable Roof Panels (RPO C2L)
This bulletin is being revised to update the model year to include 2009. Please discard Corporate Bulletin Number 08-08-67-013 (Section 08 -- Body and Accessories).
Condition
Some customers may comment on a snap, pop or rattle noise coming from the lift off roof panel while driving.
Cause
This condition may be caused by the nylon roller inside the left and/or right front roof panel latching handle becoming loose and causing the roller to move on the pin, creating the noise.
Correction
Replace the left and right front lift off roof panel handles (1) and lube. Refer to Roof Lift Off Panel Front Latch Handle Replacement in SI. The updated handles have a new design ramp insert in place of the nylon roller.
Technicians are to apply GM Super Lube® with PTFE, P/N 12371287 (in Canada, P/N 10953437) to both sides (left and right) at the following areas:
Apply GM Super Lube® around the entire guide pin ball (1) on the roof panel.
Apply GM Super Lube® inside the "pocket" of the stainless steel track (1).
Parts Information
Order the left and right handle for each lift off roof panel.
Part Number
Description
19206591
Handle, Roof Lift Off Panel - Left
19206592
Handle, Roof Lift Off Panel - Right
12371287 (US)
10953437 (Canada)
GM Vehicle Care Super Lube® with PTFE
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
B9849*
Handle, Lift Off Roof - Front - Both - Replace
0.4 hr
Add
Second Lift Off Roof Panel Handle - Front - Both - Replace
0.3 hr
Add
0.1 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
