Wires and Plugs
Old Nov 5, 2008 | 10:50 PM
Buster1's Avatar
Buster1
Default Wires and Plugs
What will some of the "fancy" spark plug wires really do for my performance. Any one done a test on a dyno or anything with and without them? What's wrong with stock plugs and wires?
Old Nov 5, 2008 | 11:52 PM
LS1LT1's Avatar
LS1LT1
Nothing.
Aftermarket wires do sometimes look prettier though.
Again, nothing.
The stock wires are fine and remain fine well into the ultra high powered/modified ranges. The stock AC Delco platinum plugs are ok as well but many have found better overall performance/fewer misfires with a good set of copper plugs (ie: NGK TR55) in most naturally aspirated applications.
Old Nov 6, 2008 | 12:35 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Don't go by what any one says,
put them on and try them yourself, stock is 7mm wire. example MSD are 8.5 mm
and will allow more current to pass with less resistance and allows a wider gap as this is where the difference is. Example stock gap .040
I run NGK's tr-55 at .059 out of the box . Now S/c'd
I run tr-6 at the .039 out of the box. With-out them I run stock gaps. Have done this on 3 Ls motors and like the result everytime! They make them for a reason.
Old Nov 6, 2008 | 02:10 AM
LS1LT1's Avatar
LS1LT1
Very good advise...of course it also applies to everything you'd just recommended as well.
Old Nov 6, 2008 | 04:57 AM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
I have come to the conclusion that if I were to put some meaty wires on my LS3 I'd go with the Callaway wires. For a reasonable price, they seem to be a huge improvement over the stock wires.
Old Nov 6, 2008 | 06:51 AM
patton's Avatar
patton
St. Jude Donor '09
stockers are fine
Old Nov 6, 2008 | 11:47 AM
timd38's Avatar
timd38
I have Granatelli wires, but Joe gave me a real deal on them and they appear to work fine.
Old Nov 6, 2008 | 11:59 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
MSD here
To Wires and Plugs
