Water pump issue...
Old Nov 7, 2008 | 08:46 PM
benspruce's Avatar
benspruce
Default Water pump issue...
I've got an 05 with 32k on the clock. I recently returned from a 2600 mile trip and the water pump failed only a mile from the dealer. That's the good news. I took it to the dealer and he replaced the water pump. The car is now running about 10 - 20 degrees hotter with the new pump. Also the fan runs at the highest speed soon after I start driving. Can anyone advise me as to why things have changed? Thanks.
Old Nov 7, 2008 | 09:01 PM
MrDrezzUp's Avatar
MrDrezzUp
Check the coolant level. It takes a bit of effort to bleed out the air after the coolant is replaced.
Old Nov 8, 2008 | 10:14 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
The dealer didn't get all of the air out of the system.
Tom
Old Nov 8, 2008 | 11:56 AM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
Tom
Definitely the problem, system needs to "burp"
Don't feel too bad, my waterpump went also a few weeks ago, had a small drip. 24k on my 06.
Old Nov 20, 2008 | 10:11 PM
skykingturbo's Avatar
skykingturbo
What is it with the lousy water pumps on these cars?
My 05/Z51 has 41K miles (out of warranty) and has just developed a leak out of the water pump.
Anyone have an expectation that GM might cover this item being only 5K over...and an item that a reasonable person might expect to last a bit longer than it has? Or, is this just one more reason why GM is going out of business.
Old Nov 20, 2008 | 10:25 PM
mksz51's Avatar
mksz51
It's certainly worth a try to see if they'll do a "goodwill" repair. Go quickly, however, other posts in General have suggested GM is encouraging dealers to cut back on goodwill repairs.
Old Nov 21, 2008 | 12:00 AM
MrDrezzUp's Avatar
MrDrezzUp
Gene Culley has a great price on the water pump and you can do the swap yourself. :-)
Old Nov 21, 2008 | 12:10 PM
schizcat's Avatar
schizcat
Good luck man. I was only 1k out of warranty last month when this problem hit. $700 later, they fixed it. Surprisingly, it was at the dealer and the part cost more than the labor. who knew
To Water pump issue...
