CAGS by-pass
Old Nov 8, 2008 | 09:03 PM
traveller's Avatar
traveller
Default CAGS by-pass
I saw a by-pass that is a fuse instead of the in-line plug. Has anyone used these?
Old Nov 8, 2008 | 09:45 PM
tomiboy's Avatar
tomiboy
That's what I have in my 09. Works great!
This idea came from Leres. I believe a forum vendor now sells them with the fuse already blown. I used a battery charger to blow mine.
SSTEVEGS's Avatar
SSTEVEGS
Yes, it works great - I have it in my '08. Do a search "LED Cags fuse"
Old Nov 8, 2008 | 09:49 PM
Motorhead-47's Avatar
Motorhead-47
Total no-brainer decision. Details in the following two threads.
http://forums.corvetteforum.com/c6-t...-led-fuse.html
http://xse.com/leres/z06/cags.html
Old Nov 8, 2008 | 09:51 PM
traveller's Avatar
traveller
Does the 1-4 light still come on, or does the fuse disable that as well?
Thanks for the replys.
Old Nov 8, 2008 | 09:56 PM
Motorhead-47
The 1-4 indicator in the dash will still be there. The small lamp in the fuse places enough current draw to fool the car into believing it is activating the skip shift solenoid....same as the old school CAGS eliminator that has been around for years. To get rid of the dash indicator you would have to have a "tuner" tune the feature out of your car's ECM.
Old Nov 8, 2008 | 10:05 PM
Magred06's Avatar
Magred06
I know it's a total Noob question, but how exactly do you blow the fuse prior to putting it in?
Old Nov 8, 2008 | 10:12 PM
Motorhead-47
The simplest way is to use a battery charger if you have one. Connect each lead to one side of the fuse and then plug the charger in....poof! Another option would be to use the car's battery with a couple of short leads to do the same thing.
Details are here.... http://xse.com/leres/z06/cags.html
Old Nov 8, 2008 | 10:16 PM
traveller's Avatar
traveller
Thanks for the info, I appreciate it.
Old Nov 10, 2008 | 01:51 PM
kramrd's Avatar
kramrd
Use a battery charger and hook it up to the leads on the fuse BEFORE plugging the charger in... I did it backwards, arched a spark and melted one of the leads on the fuse.
To CAGS by-pass
