I have about 3300 miles on the clock now and have noticed that when beating on the car a bit, the clutch pedal is very slow to come off the floor. I had an F-Body for 9 years and I thought GM cured the clutch master cylinder issues long ago. Anyone know if the C6's have the same drill-out-the-master issues that the F-body's had?
Change the clutch fluid Jim. I haven't had this problem at all and I have 13,500 miles on the car. I have changed the clutch fluid about 6 times so far.
I upgraded mine right from the start. I have some friends here that are having clutch problems at around 6,000 miles although some arent seeing anything until 30,000.
Good lord man, you are having all kinds of driveline issues.
Well turns out that statement was a lil premature clutch looks great it turned out to be a bell housing failure. i debating on keeping that clutch in there.
My clutch was done at 6900 miles on a 06, repaired under warrenty
