questions about LS3
Old Nov 11, 2008 | 03:52 PM
elyassi's Avatar
elyassi
4th Gear
Default questions about LS3
Hi all
I have Nissan patrol (SUV) with LS3 engine
In the U.A.E the heat in the summer some times reach till 50C (122F) degree
and my next project i will put supercharger .
thats why i search for High quality oil that fit with or without supercharger.
-which oil that fit with my engine from Royal Purple?
- What kind of oil cooler you Recommend?
- If i put oil cooler do i need to change oil pump?
- How much litter of oil that take LS3 engine?
- Which supercharger you Recommend from MAGNACHARGE?
Thanks & regards
Old Nov 11, 2008 | 06:41 PM
c6 batmobile's Avatar
c6 batmobile
B&M cooler
Royal purple 5w-30
about 6 or 7 quarts of oil.
You do not need to change the pump for a cooler but can get a ported one for about 120 dollars U.S.
Old Nov 12, 2008 | 02:52 PM
TurboLX's Avatar
TurboLX
Actual oil fill volume will depend on which pan you use, but ~6qts is a good starting point. The oil cooler itself adds only a small amount of volume to the system.
If you're planning on a Magnacharger, I would recommed something using the newer TVS compressors. They have significantly higher efficiency, which means less heat generation under boost. With any of their US kits, you'll probably want to upgrade the heat exchanger for your application. You should be able to just replace their heat exchanger (Raditiator) with a larger one from Setrab or B&M. You can even run multiple cores in series if needed.
Old Nov 13, 2008 | 01:30 PM
elyassi's Avatar
elyassi
4th Gear
Thank you guys
How about those items
Oil cooler
http://store.summitracing.com/partde...5&autoview=sku
Supercharger
TVS1900
Old Nov 14, 2008 | 03:56 PM
AirBusPilot's Avatar
AirBusPilot
Ok, I'll be the first to ask: Why did Nissan put an LS3 GM engine into their SUV?
Old Nov 14, 2008 | 04:48 PM
elyassi's Avatar
elyassi
4th Gear
Nissan patrol came with Nissan engine
v6 vtc4800 (( 280hp ))
and I changed the engine because I wont more power
Photo coming soon
To questions about LS3
