Once and for all 06coupe 6sp LT headers free flow catback system is throwing cel codes P0420 and P0430.
Diablo says that the predator will clear the codes so I bought it.
Will it or will it not clear these codes?
It will clear them, but how do you plan to stop them from coming back on?
At SEMA Diablo told me that the EPA will not allow them to turn off the rear o2's any more, so you light will come back on.
take it to a professional tuner and they can permanently shut these codes off. It may cost a few more dollars than diablo but you will also get a full tune and you car will run better.
Help... I was installing a pair of headers today on a 07 C6 and I have a small problem... When it came time to disconnect the rear 02 sensor on the passenger side, it is pinched in between the body and a thick wiring harness. The harness has 2 zippy ties on it I cut them but cant get the 02 wires loose. I don't even see the connector to the 02 sensor. has any body ran across this problem before? any help would be appreciated.
