NPP Retrofit Kit
Old Nov 14, 2008 | 07:04 AM
07 Z51's Avatar
07 Z51
Default NPP Retrofit Kit
OK, I am officially confused, as follows:
After looking at both websites (PD and SOC), I thought there was a NPP retro kit that did not require a vacuum tap. When I looked at SOC, I only sawe a reference to a soon to be released electric NPP retrofit. When I looked at PD, I only saw a kit that required a vac tap.
A. Was I wrong - is there not a stand alone (vac tapless) system?
B. Is the PD vacuum tap kit the only kit for retro fitting a 2007 to NPP?
C. Is the retro kit separate from the controller (wireless or dead pedal switch- do I need both?, Do they come together?
Notwithstanding the above, which is the kit to use? I have the NPP (actually Z06 mufflers) I need the retrofit and the controller. Some one please respond so I can order what I need and get the show on the road...................
Old Nov 14, 2008 | 07:29 AM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
No need to be confused, I make the NPP in a box unit, it uses a simple vacuum tap and includes all the needed parts to install and operate any bi-mode exhaust. It used by chevy dealers and even packaged with the NPP they sell on ebay. They are in stock and ready to ship. No electric units around
