Compression ratio bump on LS3
Old Nov 14, 2008 | 11:50 PM
old motorhead's Avatar
old motorhead
Default Compression ratio bump on LS3
What's a half point more compression ratio worth on an LS3 with a mild cam and bolt ons? Can a half point, or more, be had with just a thinner head gasket? If you're pulling the heads to add a thinner gasket, a little milling wouldn't be that much more trouble. Is it worth the effort? Added compression seems to be a good mod to a point. More squeeze equal more power AND mpg. Where's the cutoff when more doesn't get you more?
Old Nov 16, 2008 | 12:45 PM
old motorhead
Is 10.7 the limit as far a C/R goes for this motor? 93 octane is readily available. If a cam change is in the works, would a compression increase be of value??
Old Nov 17, 2008 | 12:57 AM
kaislick's Avatar
kaislick
i milled and used thinner gasket to get ~11.25:1, have a mild cam. I gained hp and tq across the board, no issues with 91 octane gas since the tune. It did run a little rough until i had the fuel/tune adjusted.
To Compression ratio bump on LS3
