C6 window problem
Old Nov 15, 2008 | 04:57 AM
tomburden's Avatar
tomburden
2nd Gear
Default C6 window problem
Hi guys,
My window stopped working with the auto rolldown of 1/2 inch upon entry and exit. It works normal with the window control, just not automatically. The passenger side still works properly. Is this a program problem i can fix or do i need to take it to the shop.
Thanks, Tom
Old Nov 15, 2008 | 05:26 AM
jogar80's Avatar
jogar80
Try rolling the window all the way up and holding the switch up for 2-4 seconds. It's in the manual.
Old Nov 15, 2008 | 05:36 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
re-index.
Old Nov 15, 2008 | 07:40 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by tomburden
Hi guys,
Thanks, Tom
Your window(s) need to be re-indexed by doing the following:
Old Nov 15, 2008 | 03:12 PM
tomburden's Avatar
tomburden
2nd Gear
Default Thanks
Thank you, Facade C6.
That did it.
Old Nov 15, 2008 | 04:14 PM
RPHCRMZ51's Avatar
RPHCRMZ51
Always ask the Forum first before even thinking about the STEALERSHIP.
Way to go guys
Old Aug 8, 2009 | 09:26 PM
raydawn2001's Avatar
raydawn2001
2nd Gear
that worked perfect thanks alot
Old Nov 8, 2009 | 06:10 PM
Insidious1's Avatar
Insidious1
worked for me! thanks
Old Dec 16, 2009 | 10:57 PM
SEE SEX's Avatar
SEE SEX
Me too!
Old May 27, 2010 | 03:40 PM
Nimbus87's Avatar
Nimbus87
Cruising
Great post replys. Saved me a $100.
Old Jan 11, 2012 | 09:54 AM
tinpin901's Avatar
tinpin901
1st Gear
can you or someone repost this video? i have the same problem with my driver window.
Old Jan 11, 2012 | 10:18 AM
Vette_DD's Avatar
Vette_DD
Don't really need the video.
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual, page 2-18 of the 2009 owner's manual, page 3-18 of the 2010 owner's manual, page 2-18 of the 2011 owner's manual, or page 2-19 for the 2012 owner's manual. -JFP
Old Jan 11, 2012 | 10:34 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
To C6 window problem
