Noise from transimssion/rear
Old Nov 17, 2008 | 09:41 AM
pauloc5r's Avatar
pauloc5r
4th Gear
Default Noise from transimssion/rear
I am getting a noice from transmission/rear. (Chatter) It sounds like The sound is coming from trans/rear. It does this at idle. Car is an automatic has 7300 miles on it.
Old Nov 18, 2008 | 10:50 AM
KWC6's Avatar
KWC6
I had a noise in reverse backing out of my driveway in my A6. Took it to the dealer. Their is a service bulletin out for this. They drain the fluid in the rear, fill it with some other stuff and it seems fixed. Easy solution, if this is the problem you have.
Old Nov 18, 2008 | 11:58 AM
1.8t's Avatar
1.8t
Sounds like you need the new diff fluid with more friction modifier. Take it to the dealership, there is a TSB out for this issue.
Old Nov 19, 2008 | 09:48 PM
pauloc5r's Avatar
pauloc5r
4th Gear
Just an update. They had to replace bearing. The TSB was performed first. But did not solve the problem after further inspection they found bad bearing. They replaced bearing now waiting on backordered axle part. They sent out request looking for one. I am getting the feeling that car will be there for a while waiting on this part. They are getting me a rental.
To Noise from transimssion/rear
