header question
Old Nov 18, 2008 | 04:13 AM
mountain ride's Avatar
mountain ride
Default header question
05 LS2
installed BB exhaust system with X pipe / cat back
without any mods to this system...what headers are applicable?
Old Nov 18, 2008 | 04:34 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
All
Old Nov 18, 2008 | 04:37 AM
mountain ride
alrighty then...was thinking about the header pipe and the cats...any mods?
Old Nov 18, 2008 | 04:57 AM
MARSC6's Avatar
MARSC6
Header kits will come with their own x pipe.
Old Nov 18, 2008 | 06:30 AM
timd38's Avatar
timd38
I installed B&B because they bolt up to your cat back. The others require you to get another X pipe or cut up the one you have.
Old Nov 18, 2008 | 07:44 AM
mountain ride
yeah I have been researching for myself and it looks like that...I may include this cost when I pick the cam...do it then...I like the BBB's...
Old Nov 18, 2008 | 03:32 PM
C6Manny's Avatar
C6Manny
you can order kooks headers and connection cats part # 6115-CC made to fit the corsa catback. This is what i did with my bassani catback, and i only had to cut a very small portion of the x pipe. I chose to weld it, but u can use clamps as well. This is also a bit cheaper than buying a full new x-pipe.
Old Nov 18, 2008 | 04:27 PM
BBExhaust's Avatar
BBExhaust
Premium Supporting Vendor
Originally Posted by mountain ride
05 LS2
mountian ride,
Our long tube headers will bolt directly to your B&B x-pipe. The only issue you will have would be the elimination of your cats. If you want to send me your x-pipe back I could install cats in it for the cost of the cats only or I could exchance your x-pipe with a take off. Feel free to get in touch with me if you have any additional questions.
Mark Fowler
Billy Boat Performance Exhaust
888-228-7435 Ext.18
Old Nov 18, 2008 | 07:25 PM
timd38's Avatar
timd38
Originally Posted by mark@BBExhaust
mountian ride,
Mark Fowler
888-228-7435 Ext.18
The service from B&B is unbelievable. I emailed them with questions when I did my header install on a Sunday and got a response back that day from Mark.
You may want to upgrade your tunnel plate at the same time since all the parts will be removed.
Old Nov 18, 2008 | 09:27 PM
mountain ride
thanks for the responses...I will consider the options...I like the pics of the modification...visual aid helps me go to the next step...Mark I may be contacting you as well...
To header question
