Box O Rocks
Old Nov 22, 2008 | 12:34 PM
Greenvetter's Avatar
Greenvetter
Default Box O Rocks
My motor sounds likes it has rocks in it on light throttle application after accelerating. By that I mean it does not make this noise during normal to hard acceleration, only during the time I feather it to shift or hold it at current rpm with light load. It is worse when the engine is cold. The car has 29K miles on it and is a DD. It still pulls strong and idles perfectly with no knocking.
Any ideas?
Is it common?
Timing chain?
Clutch rattle?
TIA
Old Nov 22, 2008 | 12:37 PM
mirage2991's Avatar
mirage2991
loose things can do that...like an exhaust shield ratle...maybe your synchros in the transmission are making some noise...what rpms does it do it?
Old Nov 22, 2008 | 05:18 PM
c6 batmobile's Avatar
c6 batmobile
I had a sideways exhuast clamp that made my car do the same thing at idle to about 1200 rpm. Then I moved it and it went away.
Old Nov 24, 2008 | 05:31 PM
Greenvetter
It's an 05. Thanks for the inputs. I may have to take it in and have it checked. I have the GMPP on it so hopefully whatever the problem is they cover it. It was a GM certified car when I bought it in July with 20K on it. Based on my experience so far I personally I don't think that means they did anything more than wash it, clean the interior, and add some tire shine.
To Box O Rocks
