intake shroud mod????
Old Nov 23, 2008 | 11:08 PM
HANNY's Avatar
HANNY
Default intake shroud mod????
have an 09 ls3 and have been looking for awhile for an aftermarket CAI,,,,,but also see alot of reasons/posts/specs that the stock one flows as well as Aftermarket ones.
So that in mind just thinking of doing a shroud cut to allow Cold air into the stocker.
An issue i see tho is that cutting the shroud takes away from radiator flow thus running hotter and not allowing timing pull. Is this any concern or maybe I'm overthinking it, thxs paul
Old Nov 23, 2008 | 11:26 PM
siffert's Avatar
siffert
If you dont have Z51, you could try the "free air mod" by propping your
shroud open. You are also overthinking, as most true closed cold air
intakes use the cut shroud system and those folks engines do not
run hotter.
http://forums.corvetteforum.com/c6-t...gle-bolts.html
Old Nov 23, 2008 | 11:46 PM
HANNY's Avatar
HANNY
run hotter.
thxs, i do overthink it alot. Will do that mod 2morrow. regards, paul
Old Nov 23, 2008 | 11:51 PM
siffert's Avatar
siffert
I seem to recall, somewhere I think, of hearing some '09 owners claming surges or something similar after doing that mod. So just be aware of it (you should spread it apart about 3" for max results) and worse case, you can just close it. Good luck!
PS-One of my good friends Dad owns a bunch of DQ's too-I was addicted for awhile to cotton candy blizzards.
Old Nov 24, 2008 | 02:16 AM
c6 batmobile's Avatar
c6 batmobile
The stock one does flow pretty well but aftermarkets do flow better. Callaway, vararam, lingenfelter etc.. have pretty high numbers and usually result in 10 or more hp. But you wont run any hotter cutting the shroud. I run a vararam and have a cut shroud and didnt notice any change in engine temp.
Old Nov 24, 2008 | 09:30 AM
c6-pwr's Avatar
c6-pwr
Same here...just nice ambient air being sucked into my engine
Old Nov 24, 2008 | 12:50 PM
HANNY's Avatar
HANNY
did you have a template and remove the shroud or do it on car? I'm thinking of taking mine out and cutting it but really would like a template to get that more "Factory look" Then just doing the wingnut mod. thxs fellas,,,,,paul
Old Nov 24, 2008 | 01:25 PM
siffert's Avatar
siffert
You do NOT need to cut the shroud to do the wingnut mod!!! Do one or the other but not both!! Personally I would do the wingnut mod first as taking out or even cutting the shroud in place is a PIA!! btw-Vararam and others sell pre-cut shrouds.
Old Nov 24, 2008 | 01:36 PM
BRIANSC6's Avatar
BRIANSC6
I would not spend the money on a pre-cut one as it is getting it in and out that is the tough part, cutting is pretty easy once you get it out. Make sure there are no small children around when you are working on it as there will be a significant number of expletives that come out of your mouth during the process unless you happen to be a priest, nun or my mother.
Old Nov 24, 2008 | 01:53 PM
siffert's Avatar
siffert
However, I must disagree...as I would say even a priest or nun would be four letter foul mouthed if they were taking it out.
Old Nov 24, 2008 | 03:40 PM
RoatanMan's Avatar
RoatanMan
Doesn’t the Vette-Air do the same thing..? I mean get cooler air to the intake…?
Old Nov 24, 2008 | 04:30 PM
siffert's Avatar
siffert
Yes, but you still have to cut out the shroud. Dont think its any better than the free cold air mod. Finally, except for true closed cold air systems like Vararam, Honker and Lingenfelter, all the rest still allow warm engine underhood air to enter those filters.
Old Nov 24, 2008 | 07:36 PM
red06c6hm's Avatar
red06c6hm
But none of those do anything to keep IAT temps down, and thats the biggest killer to performance when it starts to pull timing. Until I put on a new hood, the free air mod at least helps to keep the under hood temps down. The vararam does nothing for that.
Old Nov 24, 2008 | 07:57 PM
siffert's Avatar
siffert
???? I got a Honker clone now (Xcelerator) and my IAT's definately go DOWN to ambient while moving on the street. Naturally it does not do anything at idle or at stop. My last 1/4 mile run started at 77* and dropped down to 61* by the end of the quarter mile. In fact, that is THE point of having a closed cold air intake system. You can also change the IAT table in HP Tuner so it does not pull timing as well.
Old Nov 24, 2008 | 08:25 PM
red06c6hm's Avatar
red06c6hm
That's true, but without air flowing OVER the throttle body, the air pics up quite a bit of heat. That's what i was talking about. Your honker does little to reduce the heat soak from the throttle body, regardless of what you have seen. Now I'm not talking about sitting in the line waiting to run at the track, I'm talking about normal driving. the air temps go down much more with air moving over the throttle body compared to the forced air variants. The best of both worlds I suppose would be both, but I'm not convinced the forced air units do anything, but thats another loooong, discussion.
Thats why i want a callaway supercharger hood, it directs air right to the throttle body. i had something similiar on my camaro from slp, and the iat temps were always super low. I'd rather the temps were really low, instead of risking a tune mod to ignore the problem.
Old Nov 24, 2008 | 11:45 PM
danl72's Avatar
danl72
To intake shroud mod????
