What's correct front tire size??
Old Nov 28, 2008 | 12:53 PM
warlok's Avatar
warlok
Default What's correct front tire size??
First, I have searched and found contradictory info on this board. Question is: What is the largest tire you can fit on the stock C6 rims without any issues, a 295/19 or a 305/19. In addition, I can't find a post stating what in fact the front tire size should be changed to, in order to not change the geometry,ride, etc . Some have 245/40, others have 255,275,etc. Please advise. Thanks
Old Nov 28, 2008 | 01:10 PM
timd38's Avatar
timd38
Front: 245/40-18, Rear:285/35-19. Go to Tirerack.com and pick your tire and see what size rim they recommend for that specific tire.
Example, I sold a set of wheels to a forum member and they worked fine on my car, he had the same size tire in another brand and they did not fit same.
Old Nov 28, 2008 | 01:23 PM
warlok's Avatar
warlok
I guess i didnt relay my question well. I want a wider tire, I know a 295 can fit on stock rim, but can a 305 be put on a 10 inch rim. Also, what front tire size must be put on, to match up with the 295 or 305 rear setup.
To What's correct front tire size??
