GM Service Manual Inconsistent: error humanum est?
Old Nov 30, 2008 | 01:07 PM
CroOrange's Avatar
CroOrange
Default GM Service Manual Inconsistent: error humanum est?
Hello,
In the GM Service Manual, Helms edition, for the 2008 C6 Corvette there is an inconsistency.
In volume 1, section 4-83 it states on the schematic that:
  • Pin X2-6: is the rear fog lamp switch signal, circuit 1977
  • Pin X2-22: is the rear fog lamp relay control, circuit 187
In volume 2, section 11-215 it states on the terminal part list that:
  • Pin X2-6: is the rear fog lamp relay control, circuit 1977
  • Pin X2-22: is the rear fog lamp switch signal, circuit 187
These two statements are contradictory, does anyone know which of the two is correct?
As I am not a GM Dealer, I can't contact them directly to report this issue.
My current assumption is that someone screwed up on the description in section 11-215 and the schematic in 4-83 is correct.
Thank you very much,
Cedric
Old Nov 30, 2008 | 01:37 PM
GMautotech's Avatar
GMautotech
GM's service info has the same typo. I would say that the first listing you had is correct.
Old Nov 30, 2008 | 01:56 PM
CroOrange's Avatar
CroOrange
That's my current thought, but if it is not the case, it could create irreversible damage ...
a++ Cedric
Old Nov 30, 2008 | 01:59 PM
timd38's Avatar
timd38
How do you like the C5 pictures?
Old Nov 30, 2008 | 03:40 PM
TLK's Avatar
TLK
St. Jude Donor '09-'11
I don't see a real problem. The signal from the switch can also be considered the control line for the relay. It is inconsistant, but if you understand what it is saying, it still says the same thing.
Old Nov 30, 2008 | 05:31 PM
CroOrange's Avatar
CroOrange
Not when you look at the terminology for the Front Fog Lamps Circuit.
Anyway I tried it and powered the car up, the first solution is the correct solution. It's typo in the book:
In volume 2, section 11-215 based on my experimentation, it should read:
Cedric
Old Nov 30, 2008 | 06:48 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
Cro, where did you purchase and at what cost if you don't mind. I want the 06 version
thanks.
David
Old Nov 30, 2008 | 06:55 PM
timd38's Avatar
timd38
thanks.
David
I bought mine from gmpartshouse.com for $110.00, I think.
To GM Service Manual Inconsistent: error humanum est?
