First time with DRs, advise?
To wit: we only have 1/8th mile here and wonder what i can run. thinking low 8 maybe high 7 on drag radials. thoughts?
I know what your LS3 can do along with -2000 to -3500 DA at Atco helping carrying you along
Some people should really focus more on getting their own skills and programs in order instead of constantly pointing fingers and simply using DA as an excuse as to why they're not measuring up.
Tell ya what...come to any track with an altitude higher than 1000' and a DA greater than ZERO and lets see YOU doing a 11.70, 11.83 or even your car stock doing a 12.21! Let see how much your driving, tuning and car prep skills measure up higher in the sky! You would be very hard pressed, even with all your "skills" in order, to cut below 12.00 with your current setup!
Tell ya what...come to any track with an altitude higher than 1000' and a DA greater than ZERO and lets see YOU doing a 11.70, 11.83 or even your car stock doing a 12.21! Let see how much your driving, tuning and car prep skills measure up higher in the sky! You would be hard pressed, even with all your skills in order, to cut below 12.00 with your current setup!You ran at a great track (MIR) in good air with headers and I've still got you covered...I certainly wouldn't be posting too loudly with all of that going for ya LOL.
Unless you're running your car in NM or CO in the summer then WE ALL have it good, yourself included...not exactly sure what you're constantly crying about.
whenever someone talks about the Yeah, it's ALL the air/track-2000 to -3500 DA reality at Atco.
Not sure what your complaining about either! My Kooks headers untuned gave me absolutely nada in ET. Got the logs to prove it. Though the car sounds so much better
Put your headers on hanging in your garage and let's see what you can do. Though they might be a little too noisy for your sensitive ears So pray tell what your Drag Pack, Skinnies and all your weight reduction did for you? I say in -2200 DA like you got at Atco, I could do a 11.70 too while weighing far more and with far more unsprung mass!
Here are my time slips, this is what the car ran, period.
How 'bout you?
Thus, one will never be confused on the CF forums of your times and place on the LIST, though questions will always remain in many folks minds regarding what your DA number is for each slip. Thanks to the Drag Times DA Online Calculator we know your 11.70 was:
Confidentially, I think almost anyone with a driver's license who is familiar with speeding (but never drag raced at a track)) could cut similar times to yours in your own car on the same day within .05, providing you did their burnout. So much for the skill level with the A6
We'll keep this between us, just for you!
you chose MRI, your 1000 ft elevation offer is ridiculous. and here is why, if i have the best place to eat near my house why would i go a hundred or thousands of miles away to eat at a place that i know has bad tasting food
if im into road racing i would go to spring mountain, if your into 1/4 mile and atco is suppose to be the best i would go to atco,
why argue who in there right mind would go to a track that might result in worse times,
come to atco if you think its the best and prove somthing
but i guarantee that calculator isn't right. you can search back and find a video that nick yoskin posted at a rental in may 2007 when i went 11.62 he has a live video of the weather station that was a +2900 that day if you check your calculator i bet its not even close
i got sunburn that day it was so hot and sunny in the 90s but i bet the calculator says way less
. What is the date of that video run, we'll check the calulator and settle your 11.62 once and for all
Incidentally, a 11.62 at +2900 DA equates to about a 10.78 at -2,500 DA!
All the rest of the guys there had Z06's and/or C6 M6. After looking at the time, they looked at me as if to say "A chimp could drive an A6". I did a 12.08 previously at +145 DA at 1,230'. My guess is you would have done a 11.72 had you been there at MIR the same day. Oh well, we can sadly lament those glorious +100 to +200 DA freak days at 1250' once I start a new life as a Rancher and we hook up together in +3573 altitude at Roswell Dragway
heres a video of 1 run i went 11.62 that day the same as the record run, if you search you can find the video of the weather station
http://www.challengevideos.com/2007/...w338_video.php
found it
http://s22.photobucket.com/albums/b3...urrent=335.flv
Yes I made some separate threads as well JUST AS MANY OTHERS HAVE ALSO DONE before me. But you'll also notice that even after running two new bests following that original post that I STILL USED THE SAME THREAD to mention it instead of making more new threads, I should at least get a free cookie for that, no?
Atco Raceway DOES NOT have a weather station on the premises so I REALLY HAVE NO IDEA where Drag Times or ANY online site is getting their info.
No confusion on my end either.
I looked on one site the other day and it showed a disparity in barometer between Atco and a town only 5-10 miles away of over .20 (30.20 at Atco versus 30.42 at Hammonton) at the exact same moment in time.
5 miles away IS NOT where I made my passes, I made them at the 1/4 mile drag strip located at 1000 Jackson Road Atco, NJ 08004.
That weather station 4.67 miles away uses far more senstive instruments costing in the thousands over the $100-$700 handheld play toys we use. We agree to disagree and I still say:
found it
You set records at ATCO no matter the DA from +3000 to -3000!
It must be that high altitude of 33' that so much agrees with you!
