C6 HVAC Control Module
Old Dec 5, 2008 | 08:52 PM
Heimbig's Avatar
Heimbig
Default C6 HVAC Control Module
I am trying to hook up Heated Seats in a Corvette that wasn't equipped with them. I have a set of 2007 seats with power and heat. I also have a wiring diagram.
It looks like I can get a set of heated seat switches but the wiring has four wires that go to something called a HVAC Control Module which it says is in the dash under the radio. It shows 4 wires coming from this module.
Does anyone have a part number for this HVAC control module or anothername for it.
Old Dec 5, 2008 | 11:25 PM
c5education's Avatar
c5education
2nd Gear
It's the unit that you push the buttons on for your heat and A/C. You'd better be careful if there are any data wires on that circuit and I'm guessing there are if you're using 07 seat control modules. If you have a ground back feed through it then the car will not run.
Old Dec 6, 2008 | 12:09 AM
danl72's Avatar
danl72
Make sure you do it correctly.
Old Dec 6, 2008 | 01:15 AM
AfrBurNr's Avatar
AfrBurNr
Reading this made me think it would be nice if the heated seats came on automaticly when u put the temp on the hvac past a certain temp
Old Feb 25, 2009 | 10:42 PM
Heimbig's Avatar
Heimbig
Default Seat Wiring
Well- here is what I am looking at. The wiring diagram shows two wires come from the HVAC module to the heated seat module. They are wires 181 which the drivers heated seat module status signal and # 182 which is the heated seat control module inhibit signal.
Does anyone know if these two wires are hot or what type of signal they send and when to the seat module?
Mike
Old Nov 25, 2024 | 02:42 PM
duihlein's Avatar
duihlein
Navigator
Mike
Did you have any luck?
I'm researching this now.
Old Nov 25, 2024 | 03:15 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
OP hasn't posted since 2016 so I doubt you will hear from him !!
Old Dec 2, 2024 | 06:03 PM
SilverC54me's Avatar
SilverC54me
I have successfully added the factory heated seats to my 2011 vert. other than the seats, needed to find the ash tray that had the heated seat switches. Wired it all up using the factory connectors.
Gary
Old Dec 2, 2024 | 06:04 PM
SilverC54me
Gary
To C6 HVAC Control Module
