weird noise when turning left?
Old Dec 6, 2008 | 07:33 PM
ddub12's Avatar
ddub12
Default weird noise when turning left?
does anybody have any thoughts on this... 08 automatic coupe, when slowly turning to the left (like backing up or parking) i hear a clicking? noise, maybe 2 or 3 of them. this only happens when i first go into drive or reverse. so, if i put the car in reverse, turning the steering wheel to the left i get a couple clicks then it stops. i could go in circles and nothing. after, i put it in drive and go forward, hear a couple clicks then nothing after that. i can't really tell where the noise is coming from. the car has been lowered but i'm pretty sure that's not the problem. also just had a wheel alignment done. maybe the tsb rear end fluid thing? sorry for the long post. thanks!
Old Dec 6, 2008 | 11:11 PM
NYC6's Avatar
NYC6
I think you answered your own question. Im thinking thats what it is. Many here myself included have had it.
Old Dec 14, 2008 | 01:18 AM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
if you lowered it, it could be your front tires rubbing.
Old Dec 14, 2008 | 03:15 AM
ddub12's Avatar
ddub12
well, it's not the rear end fluid. had it changed, no luck. noise is now when turning both ways. i don't think it's the tires rubbing because the noise stops (when going in circles) and i don't see any wear marks inside the fenderwells. going to take it in one monday. hope it's a warranty item.
Old Dec 14, 2008 | 03:02 PM
mirage2991's Avatar
mirage2991
It's probably your posi clutchs being a little noisy during sharp turns. I had this happen once in my 3rd gen when I "forgot" to add friction modifier...once I added it, it went away...not saying C6 needs friction modifier (so check) but it could be as simple as that.
Old Dec 14, 2008 | 10:26 PM
BartonekDragRacing's Avatar
BartonekDragRacing
maybe your car isnt a ambi-turner, it cant turn left. (anyone get the reference?)
To weird noise when turning left?
