Z06 front bumper question
Old Dec 7, 2008 | 05:21 PM
2kvert's Avatar
2kvert
Default Z06 front bumper question
What, if any, parts from the original C6 bumper cover can be reused to install the Z06 front bumper cover?
Old Dec 7, 2008 | 05:53 PM
johnodrake's Avatar
johnodrake
Moderator
From what I understand, virtually nothing.
Old Dec 7, 2008 | 06:43 PM
2kvert's Avatar
2kvert
So the front brake ducts and all the filler panels should work? Any other input?
Old Dec 7, 2008 | 07:20 PM
Swiftrider08's Avatar
Swiftrider08
As John said, virtually NOTHING. Brake ducts won't work as the Z06's are different. If you mean filler panels in the wheel wells, I would say yes as the big inner fenderwells are not offered as they are glued to the chassis. Will have to come up with something to fill the gap between the edge of the fenderwell and the inside edge of the fender. Some make extensions from plastic and some have used pipe insualtion that is split and slipped over the edge of the fenderwell. I am sure some of the hardware can be reused.
Old Dec 7, 2008 | 08:57 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Filler panels are different. Only thing I can think of that transfers to the Z bumper is one plastic black part that mounts in lower middle of bumper and the fog lights. The air dam is the same also, although they do send you one with the widebody kit.
Old Dec 7, 2008 | 10:28 PM
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
The Fog Lights and the corner markers are the same.
Ben
Old Dec 10, 2008 | 07:49 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
That is correct... just about nothing but the fogs and signals can be used.
To Z06 front bumper question
