code throttle position sensor
Old Dec 9, 2008 | 11:27 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Default code throttle position sensor
out of range. Code that has popped up twice now, whats the cause?
Old Dec 9, 2008 | 11:32 PM
Sparo2's Avatar
Sparo2
Is your throttle body ported?
I've heard if the blade is not sealing completely it will cause a code to be thrown. Just what i heard.
Old Dec 10, 2008 | 12:39 AM
3 Z06ZR1's Avatar
3 Z06ZR1
no porting but F/I @8psi
Old Dec 10, 2008 | 07:55 AM
oneblackvette's Avatar
oneblackvette
Did you try the old disconnect the battery reset?
Remember to have everything turned off before you start the car after reset.
Old Dec 10, 2008 | 12:32 PM
patton's Avatar
patton
St. Jude Donor '09
hook up a scan tool
To code throttle position sensor
