corsa
Old Dec 13, 2008 | 10:17 PM
animesk8er93's Avatar
animesk8er93
Default corsa
will Corsa part #14469 2005-2007 C6 Xtreme system with quad 3.5" pro tips fit an automatic
Old Dec 14, 2008 | 04:26 PM
NeoTrunks's Avatar
NeoTrunks
I think it should fit. The Extreme's are just smaller (thinner) mufflers vs the Sport's. Of note is that you may get drone at cruise as the Corsa's resonated H-pipe was designed to deal with this on A6 cars and I believe this system is mufflers only.
Here's a link to the installation guide that may have a few more answers. As you can see the mufflers are the same length and use the same over axle pipes but the Extremes mufflers are just smaller.
http://www.corsaperformance.com/CMS/...005pdf_03f.pdf
Hope this helps.
