Fan Start Up Temp
Old Dec 14, 2008 | 04:03 PM
Wingrider's Avatar
Wingrider
Default Fan Start Up Temp
After doing a search on this, I ended up more confused than when I started. Here's my question. I have a stock OEM stat in my 2006 A6 coup. (I believe that is a 187 degree stat.) Today I noticed that my fan came on when coolant temp hit about 202-203 degrees, with outside temp being 45 degrees. Does this seem kind of low for the fan to come on? Thanks.
Old Dec 14, 2008 | 04:25 PM
mirage2991's Avatar
mirage2991
your fan comes on at 194 degrees, at around 30% (If I recall). 202-203 is something like 50%.
The outside temp doesn't influence your engine temp that much due to the 187 thermostat that is fully open at around 197 ish.
Old Dec 15, 2008 | 02:47 PM
Wingrider's Avatar
Wingrider
Thank you.
Old Dec 15, 2008 | 06:42 PM
HuskerBullet's Avatar
HuskerBullet
The OEM thermostat is 195 degrees.
Old Dec 15, 2008 | 08:13 PM
Modshack's Avatar
Modshack
Stock Fan program on an '08 FYI.....
Old Dec 15, 2008 | 10:10 PM
oneblackvette's Avatar
oneblackvette
No it's a 187.........
To Fan Start Up Temp
