oil Temp??
Old Dec 16, 2008 | 11:47 AM
mittens's Avatar
mittens
Default oil Temp??
Can some people with z51 cars take a look at there oil temp and let me know what there cars stays around? put the new headers and exhaust on and there is one oil line i can not get bent enought to get alot of air between the oil line and the header. want to make sure the oil is not too hot.
car is just over 200 normally, the highest i have seen it so far was 212, and the was running it pretty hard a few times.
Old Dec 16, 2008 | 01:34 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
My spirited driving temp is 225
Old Dec 16, 2008 | 02:31 PM
mittens's Avatar
mittens
225 is your oil temp not your motor temp correct? just making sure. If so i fell better.
Old Dec 16, 2008 | 05:47 PM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
Hell Ive had my stock 09 up to 250 on the track , your temps are just fine .
Old Dec 16, 2008 | 08:45 PM
VET4LES's Avatar
VET4LES
Sounds normal.
Old Dec 16, 2008 | 09:09 PM
8850's Avatar
8850
Here's what mine ran on a trip this past summer. Ambient temp was 97*, speed steady 77 mph for over 15 miles. Oil 237, coolant 201 and tranny fluid 192.
Old Dec 16, 2008 | 09:13 PM
LS3FORME's Avatar
LS3FORME
here in south fla summer temp are high 80-low90 at homestead,at a track day after four laps the oil get up to 270 degree, not water but oil, however the mobil 1 is supposed to be good to 300 degrees or so. I change it for every track day to keep it fresh. z51 6 sp with oil cooler, ls3. Would like a bigger oil cooler.
Old Dec 16, 2008 | 09:22 PM
lyonsac4242's Avatar
lyonsac4242
long cruise highway at 80mph about 214 or 215, after 15 to 20 minutes on track up to 284 on a 88 degree day. Obviously road racing is a different issue, but your temps are normal.
Old Dec 16, 2008 | 09:31 PM
Hairbag's Avatar
Hairbag
Once fully up to temp between 200 & 230 for most normal driving (oil temp that is)
Old Dec 16, 2008 | 11:35 PM
mittens's Avatar
mittens
thanks again, just never realy CHECKED it that hard, and was making sure all is good after install.
To oil Temp??
