A6 shift points are ?
Old Dec 20, 2008 | 12:40 AM
HOXXOH's Avatar
HOXXOH
Originally Posted by thesubfloor
I just created a separate album and posted three pretty big screenshots with almost all of the Normal, Pattern A and Pattern B shift information.
http://s155.photobucket.com/albums/s...n/HP%20Tuners/
The reason for the pink coloring is that I only had a 2.73-geared tune as my starting point so when I switched everything over to 2.56, the pink represents the values that were changed.
Hopefully this will give you everything you wanted to know but if it doesn't, just let me know and I'll do my best to help you out.
Christopher
Thanks Christopher, It's gonna take me a few days to absorb enough of this to even start the understanding process. One thing has become clear to me is that I have a lot to learn and I better get started. Maybe I'll put HP Tuners on my year-end bonus list.
Thanks again.
Old Dec 20, 2008 | 12:50 AM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Thanks again.
You're welcome. You can also PM me if you'd like and I'll send you my phone number in case you wanted to go over any of this in more detail. It's a little overwhelming at first but it starts to make sense pretty quickly.
Christopher
Old Dec 20, 2008 | 06:30 AM
wbear's Avatar
wbear
Unless you specifically change it, Pattern A is normal and Pattern B is Sport.
In regards to the numbers not making sense, the one thing I forgot to mention earlier (and it probably would have caused less confusion if I had) was that my car has 3.42 gears and I've modified my shift points based on the fact that I race the car.
Sorry for the confusion as I was only trying to show what the different screens looked like, not what the numbers should be for a given car.
Hope that clears things up (even just a little).
Christopher
Ok Chris, let me see if I have this straight.
On the HP shift speed tables:
1. If I want to change sport mode speeds I use the pattern B tab/tables to make the changes. Got that.
2. Lets say I want to change drive mode speeds. Do I Use the Normal tab/tables to make the changes or do I use the pattern A tab/tables to make the changes? Or do I have to change both and make them the same?
3, I'm still confused as to why the drive mode would need to have two tab/table choices (normal and A ). Wouldn't one be enough?
Old Dec 20, 2008 | 11:24 AM
thesubfloor
For question 1, yes that is correct.
For questions 2 & 3, for whatever reason the guys at HP Tuners don't seem to have a clear understanding of why it's like this (or better still, how and when either any of the other modes like Hot or Hot Engine ever get used) so in the interest of simplicity I just change it in both places so that I'm never guessing.
Oh and I'm not sure if this was ever mentioned before, but don't worry about changing the shift RPM values as the car only shifts based on MPH.
Christopher
Old Dec 20, 2008 | 12:58 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Oh cool, that'd be great if you would. I've got the standard 2.56 (ugh) gear '08 LS3 'cause I drive a lot of road miles. It limits my best 60' to 1.90's with the GY RFs. Much thanks.
There are two reasons why your limited to 1.90 60fts and it has nothing to do with the 2.56 gears.
1. GY RFs(use a drag radial)
2. Your stock converter(get a higher stall)
I have cut many 1.64-1.65 60fts with these 2.56 gears and a 3200 stall. Now i just went up to a 3600 stall and will be looking for 1.5 60fts with the STOCK 2.56 gears.
Old Dec 20, 2008 | 02:01 PM
HOXXOH's Avatar
HOXXOH
I borrowed some DRs one day for a few passes and saw absolutely no difference. Maybe I don't have enough power yet to require them. You're running a full second quicker than me, as my only mods are CAI and a tune at this time.
Did you gain .25 from just the converter alone? Were shift point changes needed? And probably the big question is what happened to gas milage at highway speeds? Slippage at 1600rpm and 70mph? I never drove my drag-only cars on the street, so I have no experience with converters there.
I drive about 30K a year with 20K highway. I can't let that suffer much to get better ETs a couple of times a month.
Old Dec 20, 2008 | 02:50 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
My car is NOT a drag-only car,its all purpose. I drive on the street,trips(PA,NJ and back to NY with NO problems),and to the track. Mileage is just fine with the 3200 converter(seen anywhere between 26-28mpg hwy). Don`t know as of yet how the 3600 will affect mileage, but the 3200 was great!
As far as you not seeing any gains from your DRs, that could be due to incorrect air pressures,launch techniques, and the biggest factor is your stock stall, not your 2.56 gears.
For drag racing ONLY your stall should be 400rpms less than your peak torque. I am know where near 5000rpms on my launch But a higher stall gets you closer to your peak torque, kinda like the manual guys launching there cars at 4000-5000 rpms.
If you decide that you want a stall, get a 2800 vigilanti or yank. That 2800 would be great for what you do and i bet you wouldn`t even notice the difference between the 2800 and stock 1800. When you go to the track, the 2800 will help you get better 60fts than that stock 1800 ever could.
Old Dec 20, 2008 | 11:23 PM
siffert's Avatar
siffert
You should be able to pickup at least .08 or lots more with DR's. Tony B4 is correct that it must be pressures, launch or something. I got a
LS2 with Cai, tune and headers. My headers is equal or likely less to your extra 36 hp with the LS3 & NPP. You got plenty of power to take advantage of DR's. My best was a 1.96 on runcraps (though most were 1.99's) and my best was 1.81 on DR's (1.87 at the same DA & track as my 1.96). My DR's are BFG 275/40/17 on C5 Z06 17" wheels. So as Sherlock would say, something is amiss.
Old Dec 21, 2008 | 01:17 AM
HOXXOH's Avatar
HOXXOH
Thanks Tony. I was concerned about the street usage.
I did have to chuckle about your "trips" because PA, NJ, and NY share a three way corner. My trips are like AZ to ME, then to FL and back home.
Old Dec 21, 2008 | 01:51 AM
HOXXOH's Avatar
HOXXOH
Six passes on the same day had the best DR only .06 better than the worst RF. and .01 better than the best RF. I'm pretty consistent on any given day, including six runs where the 60's were all within .01 and the ETs within .04. I wish my RT was that good. DRs were MT same size on same wheels as yours. Ya got me.
Old Dec 21, 2008 | 10:31 AM
siffert's Avatar
siffert
Ya got me.
How and how long were you burning those MT's? What was the pressures you were using for your runflats and MT's? You should see smoke on your DR burnouts for at least 3 seconds. Pressures should be about 24-26 hot for the runflats and around 21-24 hot for the DR's.
Still, 12.07 @119 is a hot time for AZ where the DA is an exact opposite
to ATCO in December ie: -2500 NJ = +2500 AZ
Old Dec 21, 2008 | 03:08 PM
HOXXOH's Avatar
HOXXOH
I was pretty much dead hooking with both the RFs and DRs so had no need to play with pressures even though they were close to what you reccommended.
Actually the 12.07 was, in fact, at ATCO in April with around a 500' DA. The best in Phoenix was a 12.14 two weeks earlier with a 1464 DA.
I'm looking forward to January with cool days and the sun warming the track. And thinking real hard about that converter now.
Old Dec 21, 2008 | 03:32 PM
  #33
siffert's Avatar
siffert
Am impressed you went all that way to Atco. No doubt we'll never see those NJ boys going to AZ I would probably try those headers first, though you would most likely pick up more time with the stall. I didnt want to mess with my street runflat traction, so I passed on the stall.
