Good luck. I've put out a few similar threads in the past... apparently, you and I are some of the very very few C6 owners ever to want a fixed roof.
The trick is not fixing the roof in place -- the roof is attached with simple brackets that could be welded... the trick is doing it in such a way that is reversible if the time would ever come to sell it and you would want to return the car to stock.
The factory C6Z06 roof brackets are welded to the halo portion of the frame hoop, and are not readily adaptable to the standard C6 halo frame hoop (at least not in a 'reversible' way described above).
I toyed with the idea of fabbing up some bolt-on "fixed-position" brackets to replace the factory 'removeable' brackets, but haven't felt particularly motivated lately... lol
I understand what you want to do, but I thought that when you had the roof in place, it acted as if you had a fixed roof. The Z06 has a lighter frame that requires the fixed roof. In fact most Z06 race cars use the regular Corvette frame because it is steel and more robust.
I upgraded the tunnel plate and the car appears to be very rigid when I jack it up. I rarely take the top off.
Cheers,
Kent
Kent,
I would be very interested in this mod...I'm 100% sure I would never want to reverse the mod. I'm actually looking to completely shave the weather stripping from outside. I'm just not a fan of targa/convertibles, and wouldn't mind having a nice headliner with a map light in the place of the rear latch.
That would look great, I love the clean FRC look. The easiest way would be for a vendor to simply make a different hatch with a much smaller glass, near the form of the FRC. But yes, it would still function like the hatch, just much smaller glass and it would save a few pounds too. Otherwise, It would be much more work. Good luck though, It would look awesome!
I upgraded the tunnel plate and get the car appears to be very rigid when I jack it up. I rarely take the top off.
If it has a steel frame it isn't a Z06. I am not sure what you mean by most Z06 cars use a stell frame, sounds like a lot of work to take everything off the Al frame and transfer it over to a steel frame or do you meant start with a base C6 and add a whole bunch of other stuff including the 7.0 l engine?
Im not a Photoshop wiz, actually this is like the 3rd time I used it but here is a pic I did in about 5-6 minutes to test the image. The first pic I found was a C6Z.
I would do it for sure. It looks great, though It would affect the Cd and it would suffer a bit, just like the C5Z.
There was a picture put out a few years ago where someone did a professional photochop of a C6 turned into an FRC style. It looked like pure SEX. I personally also prefer the FRC look, but apparently it is less aerodynamic than the coupe, which lends itself to better handling characteristics.
Just putting a feeler out there to see if anyone has converted their C6 targa into a fixed roof, or how difficult it may be.
Any stories or suggestions would be much appreciated.
The only real problem I see, would be filling in the gap and keeping it from cracking.
You wouldn't want to use a Z06 halo, unless you can weld magnesium to steel. So, using the stock steel halo, you might be able to get away with welding brackets on it and bolting the front down. In the rear though, I wouldn't think that just bolting it in would be sufficient enough to remove all flex. You would probably have to weld brackets at both ends and at several locations across the back. That would mean removing almost the entire interior to protect it from welding splatter.
Once you welded it in, you could have an upholstery shop fab up a headliner.
Real simple, C6R and the SCCA World Challenge Z06's use the standard C6 steel frame. Please note I said race cars not production cars.
Real simple, they aren't Z06's. They are C6.R's, they were developed for racing at the same time the C6 was in development. The Z06 followed and incorporated some of the technology that was used for the C6.R. The aluminum frame had not been developed yet so it wasn't available for the C6.R, I am not saying it would have been used for the C6.R, but it wasn't available.
I would love to have my C6 be a fixed roof. If someone can figure it out so the top is sturdy and smooth (I hate the rubber seal) I would definitely be on board. Keep me posted please if anyone comes up with something. I never take my top off.
Thank you for the input. That was the type of picture for which I was looking.
I'm glad I'm not the only one with this opinion. I had mentioned this to a couple of friends and they thought I was . I, also, see that you are located in Plano, TX. Do you ever go to any gtg's?
I am always looking for them but don't know where any are. I tried a couple of those ricekiller gtg's but not many vettes. If you know where they are or how I can find out I would love to get to some.
Mike
Mike
